What is that noise!
Ok this sound came on suddenly and here are some important facts:
Does not happen at idle
Does not happen while revving in neutral
Does not happen with Clutch pedal depressed and coasting at 40 mph
Does Happen when slowing down with Clutch pedal released.
Does Happen when moving through gears
Only seems to happen when there is engine power to drive wheels (gear selected and accelerator depressed.
NO VIBRATION IN THE SHIFTER!
Did see a puddle of oil under car
Engine oil is black not even remotely tan or golden colored.
oil smelled like gas and oil...
Parked car in dry spot and left it and got nothing no oil no nothin on the ground.
Car:
1977 Datsun 280z w/ Wide ratio 5spd Transmission running Synthetic blend oil in the tranny and Castoral GTX in the engine with a (god forgive me) FRAM oil filter.
Besides the oil filter what needs to be changed to stop this whine>?
  • 5 months later...
impossible to tell in the vid but from the description it sounds like diff backlash or worn diff. check to see if u have any play on the inputshaft off the diff i know i have some and i get a fair bit of whine under acceleration.
the only solution is to replace the diff and see if the problem goes away.
also make sure nothing thats connected to the engine is touching the body such as exhaust, gearbox, etc... as this can amplify the normal sound of gears and bearings drastically.
