Guest 240hybrid Posted October 31, 2002 Share Posted October 31, 2002 I've heard alot of people say you dont want a viscous 88 se model LSD, but whats the exact reason for their bad reputation? Installation difficulties, breaking, or not as affective as clutch type? Quote Link to comment Share on other sites More sharing options...
Mike C Posted November 1, 2002 Share Posted November 1, 2002 Installation difficulties. Uses different spline stub axles. One guy found some CV shafts from a front drive AMC. Quote Link to comment Share on other sites More sharing options...
Guest 240hybrid Posted November 1, 2002 Share Posted November 1, 2002 Well the 88 diff. I'm looking at has the stubs with it included in the sale. So I shouldn't run into any problems should I? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 1, 2002 Share Posted November 1, 2002 Does tne viscous LSD come with 3.70 and 3.90 ratios? Will the half shafts on a 88 bolt into a 73 240Z? Quote Link to comment Share on other sites More sharing options...
Guest Russ240z Posted November 1, 2002 Share Posted November 1, 2002 ZMike...Welcome aboard! For what it is worth I would reconsider putting your whole address on the signature bar You don't want someone else to be sporting around town in your new hybrid. Regards, Russ Quote Link to comment Share on other sites More sharing options...
Big Kahuna Posted November 2, 2002 Share Posted November 2, 2002 I am in the process of this coversion right now. Although I am using a VLSD out of a Silvia S15. I got the stub axles with my carrier too. The Whole unit drops into the case and bolts right up. I am waiting for bushings because the carrier holes are 12mm and my ring is 10mm. Once those show up I am going to drop it in. With the CV style axles I should be in business. Although I am a little concerned about how far the stub axles stick out of the case. They are a good 3-4 inches longer than the stock r200 stubs. Quote Link to comment Share on other sites More sharing options...
RB30-ZED Posted November 3, 2002 Share Posted November 3, 2002 Ive been using a R180 Viscous for about 3 years now, and love it. Its very smooth and predictable. Having said that, it will spin a wheel if one is on the dirt, but in a tight turn with the pedal down its fine. I machined the original CV down to make up a flange that I bolt my original drive shafts to. Steven Quote Link to comment Share on other sites More sharing options...
Guest 240hybrid Posted November 3, 2002 Share Posted November 3, 2002 out of a silvia huh....yeah i heard you can use them. I'll look into it. I might go for the clutch type diff though, my machinist jim at sunbelt performance says use clutch not viscous. I believe he knows what hes talking about. Quote Link to comment Share on other sites More sharing options...
Guest 240hybrid Posted November 4, 2002 Share Posted November 4, 2002 Thanks for all the replies about the viscous, buy I ended up getting a LSD clutch type from a 87 with cv's too. Now all I need it a conversion flange. Quote Link to comment Share on other sites More sharing options...
Guest 240hybrid Posted November 4, 2002 Share Posted November 4, 2002 Thanks for all the replies about the viscous, but I ended up getting a LSD clutch type from a 87 with cv's too. Now all I need it a conversion flange. Quote Link to comment Share on other sites More sharing options...
