Question on fuel rail lines
rickl750
Hi Guys,
I'm sorry for the dumb question. I have a 1978 280Z fuel injected an I'm replacing all the rubber fuel lines on the fuel rail. One of the manuals says I should use high pressure fuel lines instead of standard and I’m not sure if this info is outdated or do I need some type of special lines. I would assume today’s lines are high pressure since most vehicles are fuel injected.
Thanks,
Rick
what are the ratings on the 2 different hoses you are talking about here?
I bought some that was rated 50psi, and its being used from my pump to my damper, is this going to leak???
I guess ill have to get under there sometime and see what the ##s on it are
That's 30R7.
In one of the Z's I bought, the prev owner did the same thing - used 30R7 from the pump to the damper.
One day I turned the key and SPLASH - gas all over the floor. No fun, man. Replace it.
