jacob80 Posted March 10, 2009 Share Posted March 10, 2009 Hey guys, quick question. We have installed the 60mm 240sx throttle body and it has the little bypass valve for (i'm assuming) idle? I've noticed there is no way for air to get into the manifold while idling other than this. So my question, where do I route this hose off the bottom of the throttle body? To the intercooler piping? Quote Link to comment Share on other sites More sharing options...
jtmny1999 Posted March 10, 2009 Share Posted March 10, 2009 I just plugged mine but yeah I think it goes into the charge pipe. Quote Link to comment Share on other sites More sharing options...
jacob80 Posted March 10, 2009 Author Share Posted March 10, 2009 How are you getting air into the intake if you've plugged it? By cracking the throttle body? Is this a bad alternative? Quote Link to comment Share on other sites More sharing options...
S130Z Posted March 10, 2009 Share Posted March 10, 2009 If you are talking about the tubes at the bottom of the TB, than that is for coolant to pass through to warm the TB. There is a bump stop type screw on the TB that adjusts how open the TB is at idle. Adjust the screw to open the TB to adjust your idle. Quote Link to comment Share on other sites More sharing options...
jacob80 Posted March 14, 2009 Author Share Posted March 14, 2009 So adjust the idle with that set screw? What is the hole in the throttle body for then? It looks like a tiny hose would connect to it...whats up with this? Quote Link to comment Share on other sites More sharing options...
S130Z Posted March 14, 2009 Share Posted March 14, 2009 That connects to the vacuum advance on your distributor. Quote Link to comment Share on other sites More sharing options...
jacob80 Posted March 16, 2009 Author Share Posted March 16, 2009 Vacuum advance, on a turbo fuel injection distributor!? Quote Link to comment Share on other sites More sharing options...
