Ground control coilovers help?
Hi, I'm going to be picking a brand new set of ground control and a set of kyb shocks for my 75 280z next weeknd. I am just carious if any modify is needed to be done onto the car inorder to make the coilover work, or will everything will just bolt on with no modify. If it requires work to be done then, I won't be getting the set. So please anyone help?
exactly, there are a lot of write-ups of how to do it and what not to do, etc...but if you dont have a way to get it cut/welded by either yourself or a shop then it would be pretty difficult. if you are sectioning the strut tubes to use shorter shock-inserts (for lower ride height) then you would want to read up on it.
