AK-Z Posted March 27, 2009 Share Posted March 27, 2009 A the title says. I know holset makes some and even saw one that has both boost controlled veins AND electronically controlled. Quote Link to comment Share on other sites More sharing options...
boardkid280z Posted March 27, 2009 Share Posted March 27, 2009 Has anyone "tries missing"? Do you mean "tried messing"? You might want to spell check your posts and titles. First word of your message should be "As" not "A". And yes, there has been at least one attempt at using the electronically controlled vein turbo. You might search zcar.com. I can't remember if I saw it here or there. Of course you'll probably have better luck googling it since you'll get a much larger search base that way, not necessarily someone with a Z. Quote Link to comment Share on other sites More sharing options...
boardkid280z Posted March 28, 2009 Share Posted March 28, 2009 Here are some threads I found. http://forums.hybridz.org/showthread.php?t=145115&highlight=variable+geometry http://www.turbotalk.org/bb/viewtopic.php?f=25&t=4 Search for variable geometry or VGT, I believe there is more info on this website, and I am sure there is more out there on the web for other applications (see DSM above, and I saw a reference to a Mustang too) Quote Link to comment Share on other sites More sharing options...
S130Z Posted March 28, 2009 Share Posted March 28, 2009 I tried to start a thread on this, but it ended up going nowhere. Really, the only thing possible to do with it is to control spool times. This could be very interesting to try out, but it will take quite a bit of fondling to get right. I would try it if I had a project car, along with notching my cylinder head. Quote Link to comment Share on other sites More sharing options...
Challenger Posted March 28, 2009 Share Posted March 28, 2009 If I was to megasquirt my car and get one of the vgt Id set it where I can select between say 4 different angles. Getting the software/programs to have it continually adjusting taking in factors of TP, RPM, boost levels, temp, etc, etc would be a nightmare.... just way to many variables. With say 4 positions you could either set it up for whatever type of driving youd like, quick boost for driving windy roads or high boost at high rpm for drag racing, etc. Or you could some how set it up so it adjusts at certain RPM increments. Quote Link to comment Share on other sites More sharing options...
thehelix112 Posted March 28, 2009 Share Posted March 28, 2009 Everytime this comes up its pointed out that variable vaned turbochargers are designed primarily for diesel engines as the vanes have difficulty standing up to the higher EGTs from a petrol engine. Porsche have a variable geometry turbine that apparently cost mucho $ to make reliable, but unless you have one of them (or two) you're probably going to burn out the vanes pretty rapidly? Dave Quote Link to comment Share on other sites More sharing options...
slown280z Posted March 28, 2009 Share Posted March 28, 2009 I've ran across a working one on the net on a Mustang, but it was running either E85 or E100 (don't remember which) and it burns much cooler then gasoline. Quote Link to comment Share on other sites More sharing options...
