preserving threads during rustoration
I'm working on a stripped shell rustoration and am about to have the car blasted; then I will be priming with rust bullet in some areas and PPG epoxy primer in others. Then of course several layers of paint. What should I do with all the threaded bolt holes in the shell during the process? Will sandblasting damage them? I'm thinking about putting bolts in the holes during the blasting but them removing them before painting, then just running a tap through them before assembly. Any input?
  • 3 weeks later...
A couple places sell boxes of silicone plugs that you push or pull into the holes to keep them in good condition from start to finish. They are used a lot for OEM paint work.
When you are done, just pull them out, squeeze them to break the paint off and put them back in the box.
