Resistors
boosted280
If you are connecting the pullup resistor for tach input trigger you need this resistor. If you have a v3 or v3.57 board then you can use PWM for low impedance injectors and do not need dropping resistors for the inejctors. Any resistors in that diagram that are not related to the injectors you will need to put in your installation.
