kcambron Posted April 23, 2009 Share Posted April 23, 2009 I took a list of things I needed over to my donor car(1981 2plus2) to pull parts.rear diff,mustache bar,front diff mount and rear travers link mount.Problem, nothing but the r200 diff was there, is the 2plus2 setup different? I didn't recognize anything from my drawings!? This is going into a 73 240z. Thanks for the input, Kevin Quote Link to comment Share on other sites More sharing options...
rags Posted April 23, 2009 Share Posted April 23, 2009 81 is an S130 body style. You need to grab the pieces off a 78 or older car with an R200. Joe Quote Link to comment Share on other sites More sharing options...
evildky Posted April 23, 2009 Share Posted April 23, 2009 your stock pinion mount will work IIRC you just turn it around, the mustache bar needs to be form a 75-78 280Z manual trans or 2+2, those are the models that came wiht the R200 IIRC Quote Link to comment Share on other sites More sharing options...
kcambron Posted April 23, 2009 Author Share Posted April 23, 2009 Thanks Guys, I've read tons about this subject but get lost sometime. What does the IIRC mean?Kevin Quote Link to comment Share on other sites More sharing options...
evildky Posted April 23, 2009 Share Posted April 23, 2009 If I Recall Correctly I'm getting older and me memory ain't gettig any better Quote Link to comment Share on other sites More sharing options...
kcambron Posted April 27, 2009 Author Share Posted April 27, 2009 I found a 75 with the r200 rear end and pulled the required parts for installation in my 1973. I have done a lot of reading but am suprised to see no difference in the 1975 parts, the mustache bar seems to be the same,bolt pattern and bends,I can see no difference in the rear traverse link and the front mount looks the same as mine. Yes my car (1973)does have the 180 rear end and the 1975 car did have a r200 diff in it. What gives? Thanks, Kevin Quote Link to comment Share on other sites More sharing options...
blue72 Posted April 27, 2009 Share Posted April 27, 2009 The mustache bar should be subtly different, but not exactly the same. It repositions the diff a bit to fit the R200 in place. The front mount is a bit sturdier compared to the early cars, but it looked the same as the one on my '72 when I did the swap. Quote Link to comment Share on other sites More sharing options...
kcambron Posted April 27, 2009 Author Share Posted April 27, 2009 Thanks, did you use your existing front mount or the later model? Is the rubber part of the front mount the same?What about the rear cross link brace, it looks very similiar? Quote Link to comment Share on other sites More sharing options...
blue72 Posted April 28, 2009 Share Posted April 28, 2009 I found the side by side pictures I had taken during my swap, and the 280Z mustache bar positions the diff further back to accommodate the R200. The rear hangers are the same. I used my '72 front mount because it was in better shape than the '76 or so mount that I pulled from a j/y. Here's a link you may enjoy: http://www.geocities.com/MotorCity/Garage/6212/diffswap/diffswap.htm Quote Link to comment Share on other sites More sharing options...
