Young Z Posted April 24, 2009 Share Posted April 24, 2009 I'm on the last leg of the swap and me and my brother can't seem to figure out why it won't start. We know that we are getting air,fuel, and spark and have check the injectors with a noid light. Double checked all connections and that didn't seem to alleviate any problems. While cranking it backfires a little bit every couple of seconds. Tried starter fluid to no avail as well. We're going to try and mess with the timing some more but just wanted to see if there is anything else that could be stopping the car from starting? Quote Link to comment Share on other sites More sharing options...
woldson Posted April 24, 2009 Share Posted April 24, 2009 How do you know you are getting fuel? The starting fuild would have made it start ethier way. Sounds like timing. Have you pulled a plug? Gas soaked? Quote Link to comment Share on other sites More sharing options...
Young Z Posted April 25, 2009 Author Share Posted April 25, 2009 How do you know you are getting fuel? The starting fuild would have made it start ethier way. Sounds like timing. Have you pulled a plug? Gas soaked? Well I'm assuming that the engine is getting fuel b/c I can hear the fuel pump turn on during the 5 second prime and my auteq FPR shows 40 psi when cranking. We pulled the plugs to do a compression test a week ago and they we're soaked in fuel. Next step is pulling the front cover and making sure that the oil pump and everything is lined up correctly. Quote Link to comment Share on other sites More sharing options...
woldson Posted April 25, 2009 Share Posted April 25, 2009 Yep, sounds like your getting fuel;) If timing seems right after you check it, disco the fuel injectors, crank it a bit, let it sit an hour, repeat, then try to start it on starting fuild alone. Quote Link to comment Share on other sites More sharing options...
Young Z Posted April 27, 2009 Author Share Posted April 27, 2009 Update- Messed with the timing today and it got rid of the backfire. Still no start . Gotta recharge the battery after cranking it so much also. Quote Link to comment Share on other sites More sharing options...
Young Z Posted May 12, 2009 Author Share Posted May 12, 2009 Update- Finally runs after 4 months of hard work and frustration. When my brother started her up i felt all tingly inside . Oh and the timing was way off. Quote Link to comment Share on other sites More sharing options...
Young Z Posted May 17, 2009 Author Share Posted May 17, 2009 New Issue- Car will start but after running for 5 minutes it sputters and dies. It idles and revs fine while in neutral but dies after 5 minutes of normal driving. It does make boost but after 3 thousand rpms it hits a wall almost and refuses to rev any higher while in gear. Just changed the plugs out for new and no luck. I did notice that the spark plug holes had fuel pooling in them if that is of any help. Quote Link to comment Share on other sites More sharing options...
Z32Dreamer Posted May 22, 2009 Share Posted May 22, 2009 This sounds like it would be directly related to mafs. If your hitting a wall at 3k the ecu is either not getting signal from mafs or the flap door is not moving. Quote Link to comment Share on other sites More sharing options...
