garyneedsz Posted April 27, 2009 Share Posted April 27, 2009 info: 77 280z l28 stock my friend and i assembled my engine back together today. as i tried to fire it up, it only cranked. there was spark going through the wires. we popped open the fuel line right above the fuel filter and it was filled with gas. after about 10 tries of just cranking, i took off one of the spark plugs and there was not a drop of gas. they looked brand new out of box. i dont know if its wiring, of fpr, or what please help!! thanks Quote Link to comment Share on other sites More sharing options...
blackwidow Posted April 27, 2009 Share Posted April 27, 2009 I am guessing you are using EFI. So check to see if your injectors are firing. You can use a test light or the screwdriver method. If fuel is getting to them but they are not pulsing you will get no fuel in the cyl. And just in case that is the problem check to make sure you have secured all ground points back where they should be, and they are clean so they have good contact. Quote Link to comment Share on other sites More sharing options...
garyneedsz Posted April 27, 2009 Author Share Posted April 27, 2009 the grounds are good. i dont know whats next besides replacing the fuel pump and injectors. idont want to do that until im sure of the problem. i forgot to mention. prior to my rebuild, the engine overheated. by the engine overheating, could that have caused the pump to go out? or injectors? thanks Quote Link to comment Share on other sites More sharing options...
garyneedsz Posted April 28, 2009 Author Share Posted April 28, 2009 any ideas? Quote Link to comment Share on other sites More sharing options...
garyneedsz Posted April 29, 2009 Author Share Posted April 29, 2009 i need help, are there any fuses or any relay going to the fuel pump? i replaced the fuel pump, but there is no power going to there. Quote Link to comment Share on other sites More sharing options...
garyneedsz Posted April 29, 2009 Author Share Posted April 29, 2009 is it possible that my ecu is bad and i need another one? Quote Link to comment Share on other sites More sharing options...
essdeezee Posted April 29, 2009 Share Posted April 29, 2009 You should begin with tests from the EFI bible. http://www.atlanticz.ca/zclub/techtips/efisystem/280zfuelinjectionbook.pdf AND get yourself a copy of the FSM http://carfiche.com/manuals020/cars/ Scroll down till you find yours, and hope it's available. If not, check back in an hour. Quote Link to comment Share on other sites More sharing options...
garyneedsz Posted April 29, 2009 Author Share Posted April 29, 2009 how many ground wires come on the efi harness and where are the best grounding points at? Quote Link to comment Share on other sites More sharing options...
Pharaohabq Posted April 29, 2009 Share Posted April 29, 2009 maybe get some starter fluid and spray that in the intake, that'll tell you if you put the engine together correctly. from there you'll know then what to check next. If it doesn't start with starter fluid I'd guess your timing's off. Quote Link to comment Share on other sites More sharing options...
blackwidow Posted April 30, 2009 Share Posted April 30, 2009 did you even check to see if the injectors are firing? No need to replace them if they are fine. If they are not firing when you try to crank then take a 5 volt battery and jumper across the injector on and off, you should hear them firing or making a clicking noise. take the spark plugs out and do all the injectors one at a time while you have something like a rolled up peice of paper in the spark plug hole. If the paper is wet when you do the battery test then you have a wiring problem most likely. I believe that there are only a couple things that can make the injectors not fire in the system. also do what Pharao said to make sure everything is correct. Quote Link to comment Share on other sites More sharing options...
garyneedsz Posted April 30, 2009 Author Share Posted April 30, 2009 found out the problem. i thought the pump turns on when the key is in on position...yeah im an idiot. but, there was bad connection to so i got it. thanks guys. Quote Link to comment Share on other sites More sharing options...
blackwidow Posted April 30, 2009 Share Posted April 30, 2009 glad your up and running, good luck Quote Link to comment Share on other sites More sharing options...
