DeLorean Posted April 29, 2009 Share Posted April 29, 2009 So I bought a set of RB-R 16x8 +10, and got them mounted on some 225/50s. My car is a '73 240z. As luck would have it, they do not mount up, at all. The place I went to said I need new studs AND spacers for both the front and rear. I was expecting the front (5mm) but not the rear. The car is on Tokico lowering springs and Tokico struts. What am I missing here? Were they totally wrong? If I do need spacers and studs all around, what length studs are people using with these wheels? I guess I don't know the stock dimensions of 240z studs and I am just hoping someone can inform me of this. I did some searching, I am sure it is out there but I came up with nothing. I posted this in the 16x8 RB-R group buy thread, but haven't heard anything yet. I really appreciate the help, a friend just wrecked my car a couple of days ago so since it is in the shop, I figure I'll take care of this now. Ruined a perfectly good set of American Racing libras. $%&* life, haha. dominic Quote Link to comment Share on other sites More sharing options...
NZeder Posted April 30, 2009 Share Posted April 30, 2009 What centre bore did you order these with? I had the same size on my 71 240z fitted with no issues at all. They make the RB-R with different centre bore sizing you need the 73mm version not the 67mm version Quote Link to comment Share on other sites More sharing options...
DeLorean Posted April 30, 2009 Author Share Posted April 30, 2009 I have to measure them, but I think they are the 67mm...they would only go on the fronts with the center cap removed, but they still need a spacer. That should stick them past the fenders WHICH will cause rubbing. I'll post pictures as soon as i can, thanks for your help guys so far... Quote Link to comment Share on other sites More sharing options...
Armand Posted May 1, 2009 Share Posted May 1, 2009 You can't fit the front wheels with the center cap. You should have went with the +04 offset instead. If you are using 5mm+ spacers I would recommend longer studs. Check challenger's thread in this same forum titled "Will I need longer studs." Quote Link to comment Share on other sites More sharing options...
