L28et running rough
skib
Well I finally finished up my L28et swap (81'), but its still running rough and lacking power.
Timing at idle reads 10 on the number plate; I tryed to change the timing but got nothing, that screw on the 81 CAS is a PITA :evil:, and its prone to some back fire.
Im kinda suspecting a dead injector or two since I can pull some of them off and theres no change in the way it runs.
still kinda new to having EFI and all that, any suggestions?
If the injectors sat for a while, you might have to run the car and get it warm a couple of times to unstick gummed up injectors.
I just went through this with 4 sets of injectors and all unstuck eventually.
One set actually fouled a plug because that cylinder was too lean to fire.
I didn't use any harsh chemicals on mine.........just ran it long enough to get warm, pulled spark plugs to check if the non running cylinders were wet, and used a long screwdriver to listen to the injectors while wiggling terminals.
It took a few times getting warm and then shutting it off to let it sit for about 1/2 an hour to unstick them.
Making sure the electricity makes the trip should be first.
sometimes injectors get stuck/clogged. I have a couple of shops here in south FL that cleans/rebuild's fuel injectors for $10 dollars each.. I dont know if you can find such a shop where you live... But I would check the basics first.. if you have'nt changed the spark plugs change them, make sure to gap them...check cap, rotor , fuel pressure...
Tolulene, Xylene and acetone are all great fuel system cleaners.
Google "Homebrew octane booster"
my favorite mix is even parts gasoline, toluene and xylene. It's not suggested to run that much cleaner through for a long period of time, but for a 3 to 5 gallon mix which will be used in a matter of days, it will be fine. The finial mix is 107 octane if you start with CA 91 fuel.
I ran my 83 turbo on it, as well as my 83 NA car on it and both ran great with it in there.
ohh and I love this site....
http://www.easyperformance.com/Tech_Info/Octane_Booster_Wizard_Content.html
Before you put that in there it's important to drain the tank if it has been sitting a long time. it's a good idea to change your fuel filter as well, before and after. If the fuel system is in good shape already (tank, lines and filter are all clean) I would say you could get by without changing the filter.
Ok, so here what I found. All new NGK plugs and wires since they where black and I had the while Im at its with the wires. I installed the new plugs and cranked it over a few times with the wires unplugged and then pulled them all. They all have fuel on them except 3 and 6 which are bone dry. Connecters arnt corroded or anything so Im looking at 2 dead injectors now. Should be able to pick up some spares tomorrow and test that theory for sure.
I would put two old plugs into the non-firing cylinders and run the car to get some heat into the setup.
Just keep it running with your foot on the gas long enough to get it to operating temperature and shut it down.
Let it sit for 1/2 hour then restart and shut down so you can check if those plugs are now wet.
If they are, put in the two good/new plugs and see if you get all cylinders.
Heat does better than most anything else when unsticking injectors.
  • Administrators
With the car running and everything plugged in, have you listened to the injectors with a mechanics stethoscope to verify that the offending injectors at electrically/mechanically operating? Listen to each injector at the exact same location, they all should sound the same. A sharp "clicking" sound. If you don't have a mechanics stethoscope, you can use a long screw driver. Tip against the injector, ear on the handle of the screw driver.
If no clicking or soft clicking, wiggle the connectors on that injector. Even try swapping connectors for known running injector. (the stock EFI is not timed like spark plugs, they all open and close at the exact same time so no worries of crossing injector wires).
