slyhog22056 Posted May 2, 2009 Share Posted May 2, 2009 Recently acquired a R200 long nose differential. It has 4 spiders and a tooth count of 47:12 which makes it a 3.92. Cant find any info for this gear combination and as to whether or not it is VLSD. Was told it came out of a Subaru something or another, but was also told it was a 4.11...NOT. any way i am putting this under my 76 280Z that i just put my ford 302 into and want to know if the axle shafts i now have will just pop into the housing. it has CV housings on it now. I also figured out that i can put either my 11 tooth pinion in it to get different ratios but 11 would give me a 4.27. anyway does anyone know about this gear set 47:12 and is it lsd?? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted May 3, 2009 Share Posted May 3, 2009 Post a pic of the carrier and we can tell you if it is an LSD. I would imagine that if you could see the 4 pinions without any disassembling that it is not. Quote Link to comment Share on other sites More sharing options...
Mike C Posted May 5, 2009 Share Posted May 5, 2009 I'd like to see pics as well. But whatever you do, don't mix and match pinion gears with ring gears. That will result in a bunch of wasted gears in no time. Quote Link to comment Share on other sites More sharing options...
