rustorbust Posted May 17, 2009 Share Posted May 17, 2009 I am trying to avoid the back and forth to the parts store and hoping somone has used the stock radiator with a small block chevy and might happen to have the part numbers for the hoses? Quote Link to comment Share on other sites More sharing options...
Geking Posted May 17, 2009 Share Posted May 17, 2009 What gen Chevy small block are you running? What pump are you using? For example, there where at least 3 different pumps from 90-97... That would mess around with the mounting locations. Quote Link to comment Share on other sites More sharing options...
Titus_RacerX Posted May 17, 2009 Share Posted May 17, 2009 Bend a coat hanger to the shape you need and take it to the parts store to find a match. duh! Quote Link to comment Share on other sites More sharing options...
rustorbust Posted May 18, 2009 Author Share Posted May 18, 2009 Its a first gen small block with a long water pump.....and yes i was going to bend a coat hanger and take it to the parts store to find one but I thought I would ask if somone kept the part numbers from when they had did it. DUH Quote Link to comment Share on other sites More sharing options...
deja Posted May 18, 2009 Share Posted May 18, 2009 One thing to look at is the diameter of the hose ends. On my old SBC using the 280Z stock radiator the lower radiator fitting and the engine fitting were different sizes. You might want to look at http://www.jagsthatrun.com/Cooling-System-Parts_Order.html JTR has some reducers and slicers that work great if you need them. Quote Link to comment Share on other sites More sharing options...
