240zJon Posted May 30, 2009 Share Posted May 30, 2009 Okay so i get in my car to go to schooll and no go. I turn the key to start and absolutely nothing happens. the only thing that happens is a clicking noise. i assume the clicking noise is the acc relay in the passenger side making contact. MY starter doesn't even make a noise, theres no clicking noise. So my question is how to i narrow down my problem and fix it? i had another key switch thing and tried that but same results. Its a 72 240z running carbs but has FI electrical in it also, im hoping nothings shorting out. Quote Link to comment Share on other sites More sharing options...
dead_lemons Posted May 31, 2009 Share Posted May 31, 2009 Okay so i get in my car to go to schooll and no go. I turn the key to start and absolutely nothing happens. the only thing that happens is a clicking noise. i assume the clicking noise is the acc relay in the passenger side making contact. MY starter doesn't even make a noise, theres no clicking noise. So my question is how to i narrow down my problem and fix it? i had another key switch thing and tried that but same results. Its a 72 240z running carbs but has FI electrical in it also, im hoping nothings shorting out. possible low battery? Quote Link to comment Share on other sites More sharing options...
jerryb Posted May 31, 2009 Share Posted May 31, 2009 Pretty good guess! possible low battery? Quote Link to comment Share on other sites More sharing options...
240zJon Posted May 31, 2009 Author Share Posted May 31, 2009 nope battery is pushing out 12.7 volts. Quote Link to comment Share on other sites More sharing options...
The love of JDM Posted May 31, 2009 Share Posted May 31, 2009 solenoid, try that Quote Link to comment Share on other sites More sharing options...
240zJon Posted May 31, 2009 Author Share Posted May 31, 2009 what do you mean by try the solenoid? Quote Link to comment Share on other sites More sharing options...
The love of JDM Posted May 31, 2009 Share Posted May 31, 2009 Meaning being faulty Quote Link to comment Share on other sites More sharing options...
MoNkEyT88 Posted May 31, 2009 Share Posted May 31, 2009 Check the wires that run to the ignition key switch under the steering column. I had a 280Z that was acting weird and there was a wire unplugged. Quote Link to comment Share on other sites More sharing options...
chrism Posted May 31, 2009 Share Posted May 31, 2009 Make sure car is not in gear. Turn key to on position. Use jumper cable. Touch one end of cable to + terminal on battery. Take other end and touch post on starter solenoid. If car turns over, then you may have a bad connection from the relay to the solenoid. You can take a volt meter and check the output of the relay when the key is in the start position. If it does not read 12v, you may have a bad relay. Quote Link to comment Share on other sites More sharing options...
Oddmanout84 Posted May 31, 2009 Share Posted May 31, 2009 Hit your starter solenoid with a wrench, violence works sometimes. Quote Link to comment Share on other sites More sharing options...
240zJon Posted May 31, 2009 Author Share Posted May 31, 2009 Well Thanks for all the input i tried all of it and in the end it boiled down to dirty terminals on the starter from corrosion... i feel like an idiot. the simplist thing was the problem. Quote Link to comment Share on other sites More sharing options...
The love of JDM Posted May 31, 2009 Share Posted May 31, 2009 Glad you got it fixed!! Even if it was contact issues. Quote Link to comment Share on other sites More sharing options...
Oddmanout84 Posted May 31, 2009 Share Posted May 31, 2009 ...the simplist thing was the problem. And THAT is usually the cause of 99.9% of the problems you will have. Quote Link to comment Share on other sites More sharing options...
