jkgts1 Posted June 1, 2009 Share Posted June 1, 2009 Well I just wanted to know how you guys feel about seam welding the body while it is on a rotisserie. Of course welding to evenly distribute the heat, but do you think the body will warp more easily because it is on the rotisserie? Or am I being overly concerned? Thanks Quote Link to comment Share on other sites More sharing options...
tonycharger72 Posted June 3, 2009 Share Posted June 3, 2009 Well I just wanted to know how you guys feel about seam welding the body while it is on a rotisserie. Of course welding to evenly distribute the heat, but do you think the body will warp more easily because it is on the rotisserie? Or am I being overly concerned? Thanks I am not an engineer and don't have a lot of experience with this sort of thing, But from my own experience, when I first put my car on the rotisserie I did it before I cut out the floors and installed the new frame rails (Box section that runs the entire length of the underbody and connects the front to the rear), I found it very difficult to open and close the doors, actually pretty much impossible - getting them open was ok, but closing them was a real nightmare, I remember reading other people on here have had similar experiences with their Z's, this would suggest a bit of flex in the chassis, After I installed my new floors and frame rails, which are similar to Alterzed Z's (he has a great website with lots of great information regarding the installation of new frame rails) and Mull's, the car appeared to flex a lot less, doors now open and close ok! I would think without this sort of modification or a cage, that the car is probably going to flex quite a bit on the rotisserie, so I would probably avoid seam welding it whilst it is up there! Quote Link to comment Share on other sites More sharing options...
jkgts1 Posted June 3, 2009 Author Share Posted June 3, 2009 Thanks for the reply. Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted June 3, 2009 Share Posted June 3, 2009 If your doors line up properly now, take 'em out and put x braces in the openings and seam weld away! Yoy can even cross brace between the cross braces to box the cabin section. Not much needed - spot welds and a bit of metal - easy to remove - little time. Save you a bunch of griping when on your back welding and probably on total time. Quote Link to comment Share on other sites More sharing options...
JIM73240Z Posted June 3, 2009 Share Posted June 3, 2009 i had my new subframe connectors in before i put it on the rotisserie and then seam welded on there. doors line up fine still. i do not think it is that big of a deal. take it slow and in sections. i have seen some people have all of the suspension on while on the rotisserie, that i think is pushing it. jimbo Quote Link to comment Share on other sites More sharing options...
johnc Posted June 3, 2009 Share Posted June 3, 2009 I've seam welded three 240Zs on a rotisserie without any problems. The car must be completely stripped (no driveline, no suspension, no interior) and keep the doors closed. Quote Link to comment Share on other sites More sharing options...
jkgts1 Posted June 3, 2009 Author Share Posted June 3, 2009 Yeah the car is completely stripped and I did the sub frame connectors a few months ago. I also put in a diagonal brace in the car before I put it on the rotisserie, I guess I should be good. Thanks Quote Link to comment Share on other sites More sharing options...
