Compressor wheels salvagable?
I got these turbo's with the engine(vg30dett), but here is my immediate concern. If you look closely at the fallowing pictures, you can see some pitting on the leading edge of the compressor wheels. Are these ok? Salvagable? or will I not know completly till I tear the turbos down?
Thanks
Ryan~
I'd not touch it and run it the way it is.
Someone was running without air cleaners...
Typical FOD ingesting pattern on the leading edge of the wheel. Won't hurt to clean the wheels with solvent, but I'd shy away from removing metal and altering balance on the nose of the wheel. If they weren't vibrating, don't look for trouble by removing metal...
If it was an F15C and you were worried about something falling out of the sky in combat, I'd agree blending them to prevent stress cracks and pitching blades would be appropriate. But on this aluminum wheel....run it!
