rp975 Posted June 9, 2012 Author Share Posted June 9, 2012 Here I have assembled the runners and both flanges ready to be welded. Now it is back from welding. Then I cleaned up the welds insde the runners. 1 Quote Link to comment Share on other sites More sharing options...
rp975 Posted June 9, 2012 Author Share Posted June 9, 2012 Back from welding the plenum is not attached, I have cleaned up the welds on the top of the plenum and also machined the bottom flange to take out the warping. Next I have to make the flange for the standard twin throttle body. I will show more pics as they come. Rob Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted June 11, 2012 Share Posted June 11, 2012 wow! amazing build so far!! Quote Link to comment Share on other sites More sharing options...
rp975 Posted June 12, 2012 Author Share Posted June 12, 2012 Thanks Proxlamus, the project has been asleep for a few years because of my work but I am back on it now. Rob Quote Link to comment Share on other sites More sharing options...
zero Posted June 12, 2012 Share Posted June 12, 2012 Wow, I really like what you're doing here. I gotta say I've never seen anyone on here do the wood pressing method for making a manifold, but it's VERY cool. Also, it seems like it would be reasonably repeatable, as the wood molds are are saved. Great work! Quote Link to comment Share on other sites More sharing options...
rp975 Posted June 13, 2012 Author Share Posted June 13, 2012 Thanks Zero, It is an interesting method and means there are a lot more possibilities when fabricating. Rob Quote Link to comment Share on other sites More sharing options...
rp975 Posted August 22, 2012 Author Share Posted August 22, 2012 I have made a brace for the front of the motor for the damper. Manifold is nearly finished and last photo is how engine bay is coming along, I have to make the strut mounts for the strut bar and engine damper. Quote Link to comment Share on other sites More sharing options...
rp975 Posted August 22, 2012 Author Share Posted August 22, 2012 not sure why my photos are so large will have to look at it later to find out. Quote Link to comment Share on other sites More sharing options...
docaam Posted July 8, 2013 Share Posted July 8, 2013 Any updates on the built Quote Link to comment Share on other sites More sharing options...
rp975 Posted August 21, 2013 Author Share Posted August 21, 2013 Hi Docaam, I am about to ge t back into my project Z car, last year I won Victor Laury's Datsun Roadster in LA, so I imported it to Australia and spent 6 months getting it safe and ready for registration here. I am now enjoying driving it on weekends and will get to clean my garage up and look at what needs to be done with regards to the wiring. I did have a pretty good thread running on VQ30det.com but that site folded which is a real shame as there was a lot of good info from other users there. What are you going to do with your wiring? Cheers Rob Quote Link to comment Share on other sites More sharing options...
docaam Posted August 21, 2013 Share Posted August 21, 2013 Hi Docaam, I am about to ge t back into my project Z car, last year I won Victor Laury's Datsun Roadster in LA, so I imported it to Australia and spent 6 months getting it safe and ready for registration here. I am now enjoying driving it on weekends and will get to clean my garage up and look at what needs to be done with regards to the wiring. I did have a pretty good thread running on VQ30det.com but that site folded which is a real shame as there was a lot of good info from other users there. What are you going to do with your wiring? Cheers Rob Hey Rob, Thanks for the reply, was looking forward to your built how it drives and other things. Mine took some time mainly because of the steering rack which I changed. Engine was all done last week just took it yesterday to get the inter-cooler piping and radiator done after that wiring job will start. I am still not sure if there is NATS in my car or not as engine is slightly newer still hoping there should be. Will try to run on stock ECU else might change to stand alone adaptronic to have a cleaner look and more tunnability. Let me know if you have any suggestions regards to wiring to stand alone ECU. Posting a picture as engine was few days back Thanks Quote Link to comment Share on other sites More sharing options...
rp975 Posted August 22, 2013 Author Share Posted August 22, 2013 Hi Docaam, I am intending to use the standard engine wiring and ecu but combine with the standard z wiring, I think I will look for a similar wiring setup for a rb25 that might be on this site. Your engine is looking very good, well done. Cheers Rob Quote Link to comment Share on other sites More sharing options...
rp975 Posted November 24, 2013 Author Share Posted November 24, 2013 Some more progress, I am working on new plumbing after buying my new cross brace. Rob Quote Link to comment Share on other sites More sharing options...
docaam Posted November 24, 2013 Share Posted November 24, 2013 Looks great. Did you paint the strut bar? Quote Link to comment Share on other sites More sharing options...
rp975 Posted January 30, 2014 Author Share Posted January 30, 2014 No, it just has a blue plastic protector on from new, it will come off when the car is ready. Quote Link to comment Share on other sites More sharing options...
docaam Posted March 8, 2015 Share Posted March 8, 2015 No, it just has a blue plastic protector on from new, it will come off when the car is ready. Any update at your end, I have removed the turbo car is running fine just need to close it to make it road worthy again Quote Link to comment Share on other sites More sharing options...
rp975 Posted September 27, 2016 Author Share Posted September 27, 2016 (edited) Here is the wiring diagram for VQ30det HY34 Edited September 27, 2016 by rp975 Quote Link to comment Share on other sites More sharing options...
rp975 Posted September 27, 2016 Author Share Posted September 27, 2016 Here is page 1 of VQ30det HY34 pinouts colour coded Quote Link to comment Share on other sites More sharing options...
rp975 Posted September 27, 2016 Author Share Posted September 27, 2016 Here is page 2 The wiring diagram I found on a Russian site then translated it into English. Quote Link to comment Share on other sites More sharing options...
rp975 Posted September 27, 2016 Author Share Posted September 27, 2016 I have changed my setup for the radiator , condenser and a smaller intercooler. I am keeping in mind what was worked out in the windtunnel tests, I have the opening the same area as the two fans on the shroud at the back, so air in = air out. All this sits behind the original radiator support. Quote Link to comment Share on other sites More sharing options...
