which flywheel and clutch should i go with...
I have a 81 turbo motor and it currently has a automatic flywheel. I want to change it to a manual flywheel and clutch. I'm lost and do not have a clue what to go with after searching up.
I want to go with a 280zx 5 speed (not T5)
which set up is best...?
First, do some searching on auto to 5 speed conversions in here. There's plenty to read. Assuming you'll not be making any major performance upgrades, I'd suggest a stock flywheel and a complete clutch kit (pressure plate/rag/throwout bearing). You can get the flywheel with the transmission if you buy it from a complete donor vehicle. You'll also need the pedal box assembly (for the clutch pedal/MC) and the hydraulic line from that mc to the slave cylinder. Lastly, you'll have to make some minor wiring changes to remove the automatic safety switches.
Which one is best depends on a lot of factors. I take it this is going in the 70 240z listed in your signature?
I'd recommend getting the larger 2+2 flywheel and clutch setup, or an aftermarket setup like this http://cgi.ebay.com/ebaymotors/EXEDY-Clutch-FIDANZA-Flywheel-240Z-260Z-280Z-280ZX_W0QQitemZ310094704749QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item483315b06d&_trksid=p4506.c0.m245&_trkparms=65%3A12%7C39%3A1%7C72%3A1171%7C240%3A1318
That's an OE replacement clutch kit. If you're looking to do any upgrades i'de suggest going ahead and springing for a clutch with a little more holding force. Certainly so if you do any kind of spirited driving with the car.
Hi, I pulled my auto trans and installed a 4 speed on my 260z and there was some wiring to figure out like reverse lights and the park/neutral safety switch. I didn't have to replace the pedal box assembly even though I bought one all I had to put in was both brake and clutch pedals and springs.
