1977 280z wash engine now runs weird
  • Administrators
:wink:
TPS!
You get water in the connector of the TPS, that will create a VIOLENT rev limiter, shutting off all fuel instantly at 3200 RPM and turning it back on instantly at 2800 RPM! The car will buck violently between 2800-3200 RPM until the water is dried out of the TPS connector. I typically just remove the connector and blow it out with my mouth. Some of you can tackle this on one breath. :wink: No harm is done, doesn't affect the ECU or TPS other than expediting corrosion of the connectors due to being exposed to moisture.
This exact scenario has been covered here and every other Z car forum ad-nauseam as almost anyone that has washed their factory Fuel Injected Z car, discovers.
What takes place is the water shorts the idle circuit in the TPS so now the ECU thinks the throttle is closed. The ECU interprets a closed throttle and at higher RPM, shuts off the fuel injectors completely for emissions and to a smaller degree, mileage reasons. At any RPM above 3200, if you close the throttle, the injectors shut off completely delivering NO fuel to the engine, and then turns them back on at 2800 RPM. If you put a free flowing exhaust on the car, sometimes you can hear it kick back on with a distinct "pop" in the exhaust when it happens.
