E31 question
Guest twentysixounce
Ok, so all of the compression ratio info that I have seen only give the data for the E31 head used in combination with L24-L28 blocks. What CR could I expect with an L26 with stock bore and standard 1mm head gasket? I was lucky enough to find a virgin E31 head so I was thinking of using my L26 block instead of my L28/dished piston combo...........
