zylephone Posted July 16, 2009 Share Posted July 16, 2009 WHen at idle my car shows normal oil pressure but when the engine is reved it drops all the way down to 0. but then when i get up at speed and hold it constant speed it goes up to almost 90 i replaced the sending unit and replaced the oil filter and the oil about 2k miles ago but it has been doing it since before i did that what could be wrong Quote Link to comment Share on other sites More sharing options...
FlatBlack Posted July 16, 2009 Share Posted July 16, 2009 Have you checked the oil level? If you're burning/leaking oil you could definitely be low after 2 thousand miles. Quote Link to comment Share on other sites More sharing options...
AlwithaZ Posted July 17, 2009 Share Posted July 17, 2009 if there is not change in how the car drives, its a sensor problem(correct?)..could be the gauge, check wiring too.could be wiring burned and as the engine rattles the wires touch. Quote Link to comment Share on other sites More sharing options...
DeleriousZ Posted July 17, 2009 Share Posted July 17, 2009 There's a good chance your sensor has died, or is dying again. Those things seem to have an effective life of about 5 years before kicking the bukkit, but have been known to be DOA. The stock gauge is also pretty crappy. If you're going to replace it with an aftermarket gauge and sending unit, know that the thread for the sender is 1/8" BSPT, not NPT, you will need an adapter for it. Adapters can be found from z31parts.com or autometer, I'm sure many other places too. Quote Link to comment Share on other sites More sharing options...
zylephone Posted July 23, 2009 Author Share Posted July 23, 2009 ok i made a mistake in my first post. it stays between 30 and 60 going down the road but whenever i put my foot into the throttle at all it drops significantly. and yes the level is good it does not burn any oil either so should i try replacing the gauge? i replaced the sending unit about 3 months ago Quote Link to comment Share on other sites More sharing options...
zylephone Posted July 23, 2009 Author Share Posted July 23, 2009 oh and it also did it right after i changed the oil. it was full i know that too and it wasnt overfull and still is not Quote Link to comment Share on other sites More sharing options...
m4xwellmurd3r Posted July 23, 2009 Share Posted July 23, 2009 hey where in AZ are ya. that is weird that it would do that. the only thing I could think of is it's the wiring. my plug doesn't seem to hold tight on my S30 but it works fine. I'm not too sure how the connector looks on the Z31's though Quote Link to comment Share on other sites More sharing options...
zylephone Posted July 24, 2009 Author Share Posted July 24, 2009 i am in surprise. im not sure waht to do about. the car runs fine but i have like an ocd thing that makes me really want to make that work Quote Link to comment Share on other sites More sharing options...
m4xwellmurd3r Posted July 24, 2009 Share Posted July 24, 2009 Well you could just buy a new pressure sender and gauge, hook it up, and see what it does. Quote Link to comment Share on other sites More sharing options...
zylephone Posted July 25, 2009 Author Share Posted July 25, 2009 yeah thats true i guess it never hurts Quote Link to comment Share on other sites More sharing options...
