Xnke Posted July 27, 2009 Share Posted July 27, 2009 check your dizzy. You've got it 180* out, or the plugs shifted by one. Just fixed the same problem on a vortec V6, had the exact same symptoms. Quote Link to comment Share on other sites More sharing options...
FiveSeventyZee Posted July 27, 2009 Author Share Posted July 27, 2009 what do you mean by "dizzy"? Quote Link to comment Share on other sites More sharing options...
jay260z Posted July 27, 2009 Share Posted July 27, 2009 If had to guess im going to say the distributor. Quote Link to comment Share on other sites More sharing options...
hoov100 Posted July 27, 2009 Share Posted July 27, 2009 just in case... Quote Link to comment Share on other sites More sharing options...
FiveSeventyZee Posted July 28, 2009 Author Share Posted July 28, 2009 so assuming my spark plug wires are correct (im pretty sure they are. cant remember for sure) how would i go about timing the distributor? its an HEI by the way Quote Link to comment Share on other sites More sharing options...
Trevor Posted July 28, 2009 Share Posted July 28, 2009 http://www.classiccarauto.com/impala/how_to/install_distributor.shtml Quote Link to comment Share on other sites More sharing options...
FiveSeventyZee Posted July 29, 2009 Author Share Posted July 29, 2009 thanks guys. my plan is to just take out and re drop the distributor. my dads mechanic friend was the one who dropped it first and i feel like he did it wrong. Quote Link to comment Share on other sites More sharing options...
FiveSeventyZee Posted August 2, 2009 Author Share Posted August 2, 2009 okay I removed the distributor and spark plug cables. brought it to TDC and redropped the distributor with the rotor pointing at about 5:30-5:45 put the cap back on and redid the cables to make sure they're correct. now it won't even fire. I checked for a spark and I'm still getting one. I can also smell gas on the spark plugs so I know gas is getting into the cylinders. it atleast fired before. what could I have done? Quote Link to comment Share on other sites More sharing options...
rustorbust Posted August 2, 2009 Share Posted August 2, 2009 simply but easily missed.....did you hook the 12 volt wire back up and the wires that go from the inside of the distributor to the cap?? Quote Link to comment Share on other sites More sharing options...
FiveSeventyZee Posted August 2, 2009 Author Share Posted August 2, 2009 yes. I have sparks. something else must be wrong Quote Link to comment Share on other sites More sharing options...
jay260z Posted August 2, 2009 Share Posted August 2, 2009 Was the TDC on the compression stroke? An easy way to tell if its the compression stroke it to get a buddy, take out the #1 plug, hold your finger over the spark plug hole, have the buddy crank the engine over untill the air in the cylinder pushes your finger off. As soon as your finger is pushed off stop cranking, that should be TDC on the compression stroke. Then take the cap off the distributor and see what contact in the cap the rotor is pointing towards, this should be where the #1 plug wire is on the cap if its not then re-stab the distributor so it is. Quote Link to comment Share on other sites More sharing options...
FiveSeventyZee Posted August 2, 2009 Author Share Posted August 2, 2009 That's how I did it. and it's not firing Quote Link to comment Share on other sites More sharing options...
jay260z Posted August 2, 2009 Share Posted August 2, 2009 If you have another dist. try to use that one as a test. The plugs may be to satirated with fuel to start the engine if you konw the plugs are firing properly. just a thought Quote Link to comment Share on other sites More sharing options...
FiveSeventyZee Posted August 2, 2009 Author Share Posted August 2, 2009 I don't have another distributor to test with but I tested (more than one) spark plug and I was getting sparks. I thought it might be flooded. but how do I fix that? I figure just let it sit right? I can always test it tomorrow/today technicaly to see if it was just flooded. also, bad spark plugs wouldn't cause this right? that may cause it to run weird but it would fire right? because my plugs were pretty bad. I cleaned them. I figure they make a spark then they're ok. but I do have new plugs. we were kind of hoping to hot use them until we got it running. Quote Link to comment Share on other sites More sharing options...
Guest kostiakot Posted August 2, 2009 Share Posted August 2, 2009 Sounds like you have a passage blocked or something Quote Link to comment Share on other sites More sharing options...
