Red light in dash?
WreZ
So the area in between the speedo and tach is now completely red where it once just said "ok" in green letters, i'm guessing red is not a good color ever so can someone tell me whats going on? also if it helps my oil pressure sender has been acting up and needs replacement, if that is the cause of the problem then I guess i answered my own question:biggrin:
First of all, what car is this on? Be more specific in your posts, we can only guess so much.
That said, read the manual for your car. Not even the service manual, but the owners manual, the one that normally lives in the glove box when you buy the car new. If you don't have it, you can download a copy from Xenon's website, specifically http://www.xenons130.com/reference.html , for the 280ZX manuals.
Also, that little red-square is the warning system on the S130 and Z31 cars. It indicates problems with the car. Push the little button next to the light. It will blink what's wrong. For fluid levels, the sensor may also be bad. In which case you either disconnect the sensor, and loose the warning for that fluid being low, fix the sensor, or find a working one. In any case, RTFM. There's are sections in both the owners manuals and service manuals that cover the system thoroughly.
WREZ, really......come on......
What? its an honest question, i've had my Z for less than a year and i don't exactly know everything about it. I need to know if its something I should be concerned about
