Guest Anonymous Posted January 11, 2002 Share Posted January 11, 2002 Not sure what forum to throw this into but... Just saw an odd website ( www.renegadehybrids.com ) and was left wondering if a 914 (which I think has for all intensive a purposesly built VW engine) can fit a SBC, then why couldn't a SBC fit into a bug? I am sure that the VW transaxle would need replaced but a porsche might work right? Even if it meant that the firewall had to moved it would still be really cool. I think I have too much time on my hands Quote Link to comment Share on other sites More sharing options...
Tim240z Posted January 11, 2002 Share Posted January 11, 2002 This was a site posted by GrumpyVette recently about a Caddy drivetrain in a bug: web page Tim Quote Link to comment Share on other sites More sharing options...
stony Posted January 11, 2002 Share Posted January 11, 2002 isnt the 914 mid engine? thats why.... and bug is rear engine.... It can be done and ive seen it but usually you chuck the pan and build a custom frame with engine in front and radiator in the rear Quote Link to comment Share on other sites More sharing options...
Trevor Posted January 11, 2002 Share Posted January 11, 2002 Some 914s had 6 cyls, but most are 4 cyls... Putting a SBC v-8 has been done - by Renegade, but they have to move the water pump over to a bracket on the side of the block. There is no more room up front. I suppose someone has stuffed a SBC the back of a Beetle. Seems like it would be doing wheelies ALL the time. Quote Link to comment Share on other sites More sharing options...
Guest RXO510 Posted January 11, 2002 Share Posted January 11, 2002 Finally got this to post right. Go to the bugs section. Check out this V8 bug! "Munsta" J&G http://www.geocities.com/MotorCity/Garage/1811/ Quote Link to comment Share on other sites More sharing options...
SpeedRacer Posted January 12, 2002 Share Posted January 12, 2002 Oh yeah........ Rod Simpson Hybrids http://www.pacificnet.net/v8/ plus a few more make a kit to put an SBC into a Porsche (including the 914). BTW - while the 914 was VW engine based the 916 had a boxer 6 in it. Quote Link to comment Share on other sites More sharing options...
SpeedRacer Posted January 12, 2002 Share Posted January 12, 2002 Had a guy in the club for that had an SBC in a VW bug. No back seat (made it mid-engine) and pulled the front wheels off the ground with little effort but not as easy as the guy with the Porsche 911 with a 383 in the back. Quote Link to comment Share on other sites More sharing options...
denny411 Posted January 12, 2002 Share Posted January 12, 2002 With a torch and a welder...anything will fit Quote Link to comment Share on other sites More sharing options...
Guest jens Posted January 12, 2002 Share Posted January 12, 2002 The aluminium rover v8 3.5-4.6 or leyland 4.4 is the only engine light enough to get reasonable handling in a bug unless you want mid engine. The 914 has rear engine like the bug. The 350 swapkit for the 914 excist and is claimed to work fine with serius suspension mods. Quote Link to comment Share on other sites More sharing options...
jimzdat Posted January 12, 2002 Share Posted January 12, 2002 quote The 914 has rear engine like the bug. Sorry, Jens; but the 914 was considered a mid-engine car, not rear-engine like the bug--it's engine was in front of the transaxle, right behind the passenger compartment; while the bug's was hanging on for dear life at the rear of the transaxle. Quote Link to comment Share on other sites More sharing options...
ZROSSA Posted January 12, 2002 Share Posted January 12, 2002 There are about three different companys out there that also put 350 chevs into the 911. This hangs out the back like the vw. They say in the chev in the 911 has the same weight distribution as the standard 911 turbo. It has a higher center of gravity though and the turbo was never known for it cornering anyway. Douglas Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 12, 2002 Share Posted January 12, 2002 I've seen the rover swap done into a VW, the SBC would fit too, although I can't imagine replacing a sub 200 pound motor with a 500+ lb motor and doing anything wonderful for the handling. You'd also need some sort of turbo porsche transaxle or it'd probably be toast in short order. I'm not sure what the flat 6 weights in a porshe, but for a car that already pushes pretty bad I can't see adding the additional rear weight of a V8, making it handle any better. I know you add radiators up front, maybe that helps a bit but still... The rover conversion I saw was in a baja type bug (chopped fenders and rear end) and was raised up a bit, but even with that he pulled out and wheeled for a good 50 feet no problem. The wheels on a bug are back quite far in the rear seat. Since import racing is all the rage, I thought a V-tec (I know honda, but hey this would work...) that had been leaned on within a inch of its life would be REAL cool behind the front seats in a beetle. All that and you get the benefit of good traction and weight distribution. Even cooler put it in a Karma Ghia! Somtimes a tack hammer is more suitable than a sledge, hell VW's with hot boxer fours have been running 8's and lower for years. Regards, Lone Ps: I think the people to contact for an adapter if anyone is serious about a V8 bug is Kennedy Engineering, they do lots of engine adapter plates .... Quote Link to comment Share on other sites More sharing options...
Guest jens Posted January 13, 2002 Share Posted January 13, 2002 Here is a 914 v8 conversion http://home3.inet.tele.dk/box164/html/fischer_part_2.html I think its very expensive because of the transmission and suspension swap. 911 parts isnt exactly cheap. A fwd engine with cabel operated transmission/automatic and all fitted in the rear of a bug would be cheaper but not easy to do as a subframe is necessary. like the dubsport vr6 conversions in a golf mk2. www.dubsport.com Look also at the twin vr6 turbo golf. This way brake upgrades in the rear is already done and the weight transfer would be like a mid engine car. Quote Link to comment Share on other sites More sharing options...
