Anyone ever thought of using a V4 engine?
AkumaNoZeta
I just have a case of insomnia and when I can't sleep I talk about things I shouldn't. I'm usually a sleep HOURS before the time I posted the original message.
But I do like the V4, it just sounds cool. I think they should make a new one, Toyota should do it, put it in the Corollas. Also make them RWD with a 7 speed close ratio manual transmission.
Grim check out Gollums post in the High Revving V8 thread. He talks about the Honda VFR800 which seems like could be a killer little V4. A little google research and most people show you can get close to 200 hp with a supercharger. Probably more with internals, cams, turbo's, etc. But the weight savings could be killer, not to mention mounting the engine way close to the firewall. I think it would be an awesome project if you could prep it and make it super light, CF/FG, no interior, etc. It'd be quick, peppy, sound good, and handle like none other!
The V-Max has a 360 degree crank, so it won't have that unique V4 sound, nor would it ever work for combining two like I'm researching, to achieve a flat plane crank sound.
I'm going to be starting my own thread in just a moment if you sit tight...
EDIT: I'm sorry, I've found myself wrong. There HAVE been flat plane cranks for the V-Max, but I haven't figured out which were are weren't. It might be a case of displacement, as with most bike engines.
A dual plane crank is also known as a 360 degree crank. It might not mean having a fire every 90 degrees, as in the case of a V4 that's impossible, it just means that it has multiple planes and therefor isn't a "flat" crank.
Oh, and regarding the VMAX engine, the info I'd found in the first place was wrong. ALL Vmax engines are flat cranks. They're a 70 degree block design though, not a 90 degree, which is what gives them that slightly different sound compared to the VFR engine, or other 90 degree V4 engines. A 90 degree V4 like the VFR will sound rough at lower RPMS but once it gets going fast enough it smooths out. The VMAX engine never does smooth out, therefor resembles the sound of a crossplane V8 much more than the 90 degree V4s.
