Guest Anonymous Posted March 1, 2002 Share Posted March 1, 2002 I searched the forums for a topic I thought I read about deleting the stock amp gauge in the 240Z. I want to replace the amp/fuel gauge with my AutoMeter fuel gauge and need to know what to do with the amp gauge wiring. Do I just wire it together and insulate it well? Any special considerations? Note- I have a Summit fuel cell with sender so the fuel gauge should just hook right up. Quote Link to comment Share on other sites More sharing options...
Owen Posted March 1, 2002 Share Posted March 1, 2002 I just cut it and insulated the end. You can use either tape or a fully insulated insulated plastic crimp on connector like I did. Owen Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 2, 2002 Share Posted March 2, 2002 Perhaps I should have started my post with "I am an electrical bonehead". What do I do with the two large wires from the amp gauge? When the gauge is disconnected there is no electrical to the car, do I splice them together or will that burn my car to the ground? The answer is probably obvious to everyone but me. Man, I really need to read an electrical manual. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 2, 2002 Share Posted March 2, 2002 Originally posted by KicknZ:Perhaps I should have started my post with "I am an electrical bonehead". What do I do with the two large wires from the amp gauge? When the gauge is disconnected there is no electrical to the car, do I splice them together or will that burn my car to the ground? The answer is probably obvious to everyone but me. Man, I really need to read an electrical manual. Jerry, I connected mine with a small screw/nut and taped it up well. I put a 100amp alt. on and didn't want to find out what effect that would have on the gauge. No fires over the last year since I did that. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 2, 2002 Share Posted March 2, 2002 Thanks Thill, that is what I thought but electrical is a concept that is difficult for me, therefore it's scary. Quote Link to comment Share on other sites More sharing options...
RB30-ZED Posted March 2, 2002 Share Posted March 2, 2002 On the Australian model and im guessing the US one, you will find on the drivers side kick panel above the relays two big white wires that have male and female conectors,if we call one, wire one, and the other wire two, then all you have to do is disconnect all wires and plug the male of wire one in to the female of wire two and the same for the other, this bypasses the gauge and leaves the wires to it dead. Steven Quote Link to comment Share on other sites More sharing options...
pparaska Posted March 4, 2002 Share Posted March 4, 2002 The US Z is the same, but then I think all power to the fuse box and accessories would be shot. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted March 4, 2002 Share Posted March 4, 2002 Believe me - just short the two big wires together - all you are doing is removing the ammeter. If you were removing the voltmeter, you would have to leave the wires open. Quote Link to comment Share on other sites More sharing options...
pparaska Posted March 4, 2002 Share Posted March 4, 2002 Z-sleeper, I did exactly what thill did (above). That kept power to everything and just took the Ampmeter out of the picture. Quote Link to comment Share on other sites More sharing options...
