RUZN Posted September 5, 2009 Share Posted September 5, 2009 OK so since I want to build a Really nice oldschool VG30E-TT I figure Ill pull the rest of it out of my Z31 and build it on the Bench. So For now I want to make another type of Hybrid. The KA24DE-T Z31 So far I have Aquired: 1993 240sx KA24DE motor in good shape complete with 5SPeed Transmission and Razo SHort SHift. Next I am going to get Exhaust piping/ Welding materials/Some Steel and basic seal kits and rings for the Motor as Well as Pistons as I will keep stock ROds and Crank. Also Have injectors from the wrecker that I plan on getting cleaned and Mapped. So in the next few Days I will be posting tons of pics Very Detailed this time around and Exact costs in materials to build a Fairly decent KADE-T motor that fits into a Z31 without to much issue. *hehe yeah right!!* So. Stay tuned as I figure since there is millions of KA's in the world waiting to be Freshened up. Lets see total cost to at least make 250+hp out of a KA thus making a fairly decent DD Z31 with the wide selection of parts offered for KADE motors/Transmissions Motor Pic Before! Soon to be After hehe Quote Link to comment Share on other sites More sharing options...
DeleriousZ Posted September 7, 2009 Share Posted September 7, 2009 What are you planning to do about the front sump oil pan? Quote Link to comment Share on other sites More sharing options...
RUZN Posted September 7, 2009 Author Share Posted September 7, 2009 this is what I needed to hear lol. I remeber reading something about it dosent clear the Swaybar or something by 1" inform me please.. just tearing down the motor now so cleaning it all Making Manifolds and Making a new Air intake Plenum Also using MIZUMO motors Full engine Kit (All seals gaskets ect ect and Rings NPR) $285 plus $50 shipping 2 day Quote Link to comment Share on other sites More sharing options...
DeleriousZ Posted September 7, 2009 Share Posted September 7, 2009 I've never tried it, or seen anyone else try it. It doesn't clear the sway bar in 510's, I have no idea what the clearance is like in a z31 though. Quote Link to comment Share on other sites More sharing options...
RUZN Posted September 7, 2009 Author Share Posted September 7, 2009 So I started a mockup Flange and Pipe for my Project 300z (Spec-SXT) hehehe and heres the first flange-pipe. So far so good Fits perfect seals nice and after a couple hours I should have a basic Manifold constructed Again Mock piece to see fitment or flange Quote Link to comment Share on other sites More sharing options...
RUZN Posted September 10, 2009 Author Share Posted September 10, 2009 ok so went in town and got some 1/2" by 3" Flat Bar Steel. took the old Gaskets from the exhaust manifold and a can of spray paint. Laid out the flat bar sprayed over the gasket and Vwala imprint of where I need to drill heheheh... Then I proceeded to cut the center hole which is now 1 3/4" and the ports on the L24 err I mean KA24DE are 1 1/2" so when I finish porting those exhaust ports Ill port match to just under flange size to make sure there is no pressure trying to escape out the flange. I then welded 1 3/4" Exhaust piping to the flanges a good solid doubled bead LOL and the pipes extend out about 3" at various angles. So I plan on going 4 to 2 to Turbo Flange so it hits the turbo in a V pattern. Then I want to have a 2 1/2" Flexpipe (ughh $60 dollars!!) from turbo to under car and make a External Wastegate I guess and then the rest is easy lol. So more pics later tonight as I weld weld weld away! got some serious flash!! gawd I hate my welder! Quote Link to comment Share on other sites More sharing options...
DeleriousZ Posted September 10, 2009 Share Posted September 10, 2009 This probably would have saved you a ton of trouble http://cgi.ebay.ca/Nissan-KA24DE-Steel-Exhaust-Flange-1-2-CNC-Machined_W0QQitemZ270334885425QQcmdZViewItemQQptZRace_Car_Parts?hash=item3ef136fe31&_trksid=p3286.m20.l1116 Don't forget after your manifold is made to cut the flange between each pipe to allow for thermal expansion. Also enlarge the outer bolt holes by a bit for the same reason. Quote Link to comment Share on other sites More sharing options...
RUZN Posted September 11, 2009 Author Share Posted September 11, 2009 yeah mine isnt filed or made pretty yet but it was made by me for a total of $15 CDN same day shipping same day creation LOL... its the fun of the process for me. But damn thats one SHINY piece of Metal!! hehe and yes I did enlarge holes when I made em for that reason. I also plan on making slight cuts like 1mm deep sorta like the Aluminum cooling towers on a PC chip ya know..? for better heat dissapation. it will be wierd but fun im hoping for a FALLOUT 2 Look. should be neat Quote Link to comment Share on other sites More sharing options...
RUZN Posted September 11, 2009 Author Share Posted September 11, 2009 And BTW I measured up the motor width and length as well as were the oil pan sits and it looks like it should just go right in there. I kinda have a lasting memory that the 240SX chassis was based off the 300zx wasnt it? I mean if you look at the 89-91 240sx and a Z31 beside eachother they do look similar in shape.. But hey its a Custom build so whatever needs to be done will be done! Quote Link to comment Share on other sites More sharing options...
Aaron D Posted November 8, 2009 Share Posted November 8, 2009 Any updates? Quote Link to comment Share on other sites More sharing options...
