FiveSeventyZee Posted September 26, 2009 Share Posted September 26, 2009 As the title states, my fuel pump went out. I wasn't getting strong pressure out of it but now I'm getting nothing. I was wondering what would be better for my car in terms of performance? Would my fuel pump choice change anything? What about costwise? From what I have found electric seems to be cheaper mainly because they are universal. Quote Link to comment Share on other sites More sharing options...
ktm Posted September 28, 2009 Share Posted September 28, 2009 .....and your car would be what? Engine? EFI or carb? Really, more information is needed. Quote Link to comment Share on other sites More sharing options...
hoov100 Posted September 28, 2009 Share Posted September 28, 2009 going from mechanical to electric will cost more, then buying a new mechanical pump, theirs no point in getting a high end fuel pump as your going to have to regulate it down to stock fuel pressure anyway. theirs no pro's or con's to either in a stock application. Quote Link to comment Share on other sites More sharing options...
FiveSeventyZee Posted September 29, 2009 Author Share Posted September 29, 2009 well from what I've found a new mech pump costs around $75 but I'm finding electric pumps from $25-200 and it's a 240 with a chevy 350 from an iroc camaro with a holly street dominator intake, edelbrock 650 carb and an edelbrock proflo triangle Quote Link to comment Share on other sites More sharing options...
DuoWing Posted September 30, 2009 Share Posted September 30, 2009 But with an electric pump you'll probably need more hosing and have to purchase a regulator as was mentioned which will raise the price anyway. Not to mention then having to wire it up. You'd probably want a relay with it too. I'd say go with the mechanical, it'd be much easier and less headache even if it did come out slightly more expensive. Quote Link to comment Share on other sites More sharing options...
sweetleaf Posted September 30, 2009 Share Posted September 30, 2009 I would also question why the pump died. Are you sure you don't have a clogg in the fuel system? Maybe the pump did just die, going to elecric isn't as big of a deal as most are making it out to be. The wiring is simple. Quote Link to comment Share on other sites More sharing options...
Iceman Posted September 30, 2009 Share Posted September 30, 2009 I hooked up an electric fuel pump and a regulator in my truck for around $60 total. The price difference between the two doesnt have to be huge. If you go to electric, make sure you get an oil pressure switch so it turns off if your engine dies or you get into an accident. I like electric because you can have a hidden switch to turn it on. If someone tries to steal your car, they might get a few blocks down the road with what's in the bowls before the engine dies and they need to ditch the car. Quote Link to comment Share on other sites More sharing options...
langfordchuck Posted September 30, 2009 Share Posted September 30, 2009 As other posters on this site have noted, a cheap electrical pump will be noisier, with a noticeable ticking noise. If you don't care about noise, no problem, if you want the quiet than worth buying a better pump. Quote Link to comment Share on other sites More sharing options...
FiveSeventyZee Posted October 3, 2009 Author Share Posted October 3, 2009 sweetleaf said: I would also question why the pump died. Are you sure you don't have a clogg in the fuel system? Maybe the pump did just die, going to elecric isn't as big of a deal as most are making it out to be. The wiring is simple. This caught my eye because all I can say for sure is that it wasn't making a vacuum. I had a buddy come over and help me out, we pulled the fuel pump and we sprayed air through it. we refitted it and it was fixed. any ideas what it was? my best guess is something clogged but I have only been using a short length of fuel line and a filter before the pump. Quote Link to comment Share on other sites More sharing options...
Guest custom280z Posted October 3, 2009 Share Posted October 3, 2009 go electric 40-50 buck's last for ever! Quote Link to comment Share on other sites More sharing options...
