Remote oil filters
Is anyone using remote oil filters with there sbc swaps to make filter changes easier?
My car has long tube headers witch run under the filter and its a royal pain to change the filter and not make a huge mess all over the header.
Im not sure what parts to buy if i do move the filter off the block, witch one of these would be a better choice of the two.
this
http://www.summitracing.com/parts/CTR-22-580/
or this
http://www.summitracing.com/parts/CTR-22-592/
thanks
  • Administrators
I did a remote oil filter, placed it on 45 degree angle, driver-side frame rail forward of the rack, just behind the radiator. Made oil changes a breeze and did allow a little more freedom in exhaust routing, not having to make room for oil filter changes. :2thumbs:
Edited by BRAAP
I have the trans-dapt dual filter unit on the boys z. Look for a pressure drop from your original oil pressure reading. It makes changing oil alot easier but what I was looking for is that alcohol puts water, methanol in the crank case and the dual filter elements let me be more comfortable than I was with just one filter and changine it every race.
