660Z Posted June 30, 2002 Share Posted June 30, 2002 I just got the exhuast on my 240 and had to cut a section of the sparetire well out for the flowmaster muffler. So now it`s basicly useless for a full size tire.I have to remount my fuel pump becaulse I changed over from a r180 to a r200 and the mustache bar sits back to far for the fuel pump mount to work....ok long story short im thinking about mounting the pump in the spare tire well and covering the top with a metal door of some type...what do you think? what do you use this space for?? Quote Link to comment Share on other sites More sharing options...
blueovalz Posted June 30, 2002 Share Posted June 30, 2002 I cut mine out completely and filled it with a battery, fuel cell, fuel pump, and filter. Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted June 30, 2002 Share Posted June 30, 2002 Sawzall my friend. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 1, 2002 Share Posted July 1, 2002 As smooth looking as Dan's setup there is, I think the sheetmetal cover is its nicest feature, very nicely done. Regards, Lone Ps: Ever see his old exhaust? Just kidding Dan... Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted July 1, 2002 Share Posted July 1, 2002 Very nice job Dan! I have air in mine as there is no spare at the moment. Gettin car lighter by the moment. Just hope for no flats Mike Quote Link to comment Share on other sites More sharing options...
Mike C Posted July 1, 2002 Share Posted July 1, 2002 Mine has a spare tire...and a 8" Kicker sub. I cut the hold down bracket out and flipped the spare upside down. You can gain nearly 2" of clearance in the tire that way. Eventually, when I have the tank out, I'll weld a nut to the bottom of the well and use a bolt to hold the tire down. I Then cut a 3/4" piece of MDF to fit the floor and flush mounted the speaker. Their is a 3/4" step in the carpet between the strut towers, but it is virtually undetectable and I get to keep my spare! (Hey, it IS a street car!) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 1, 2002 Share Posted July 1, 2002 Good idea on the sub woofer. Mine holds what looks like the original 240z spare, probably still has some air (I've added, it was low) from 1972 in it. Regards, Lone Quote Link to comment Share on other sites More sharing options...
73BOTIZ Posted July 1, 2002 Share Posted July 1, 2002 Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted July 3, 2002 Share Posted July 3, 2002 Hey Mike D. Your pic went red X. Write back and give a description at least. Quote Link to comment Share on other sites More sharing options...
Kevin Shasteen Posted July 3, 2002 Share Posted July 3, 2002 Originally posted by Lone:.., Mine holds what looks like the original 240z spare, probably still has some air from 1972 in it. Regards, Lone Lone, Looks like my 78 & your 72 actually do have something in common after all. My Z also houses the original spare. You know (regarding the original air in tires) you should replace the bad air with new air every now & then/or the tire(s) might rot from the inside out Kevin, (Yea,Still an Inliner) Quote Link to comment Share on other sites More sharing options...
