260z with JTR 350 swap ... should I buy?
I came across a 260z with 350 swap.
At first I was like WOW ...
Then I looked closer ... under that Macco $199 special there's a ton of issues
Interior was shot. Seems like water poured into this car.
paint job was one of the worst I've seen with bondo and pot riveted panels that were on the verge of falling off the body.
but the engine bay showed promise
looks like home-built mounts and the wiring inside was dubious .. but I've seen worse.
anyway ... I figured a rebuilt 350 engine with the swap pieces was worth about $1,500 to $2,000. I have a 240Z that's worth dropping it into. any thoughts? The transmission was a TH350.
Guest stdgrabbag
hmm does it run and drive fine? if you dont already have an engine and mounts and you already have another car that you want to put it in, i would think if the price is right and it runs good go for it. as long as your not using that chassis
It looks/sounds like a quick swap in a so-so shell. I wouldnt want to have to deal with somebody elses short cuts and half-assed jobs.
You already have a z and wouldnt even use the shell? Thats even more reason to stay away in my opinion. The engine mount kit can be had cheaply enough (new or used) and a motor with a known/solid history and build quality goes a long way in my mind...
