82 280ZX stutters at 4800rpm and up
ARRESTmeRed04
ok i've tried to search fo it and i downloaded the FSM but i just can not figure this thing out, it runs great all the way to 4800rpm then it starts to stutter but will continue to pull to redline. If you back off the throttle just a little bit the stutter goes away. And it also only does it under a load, revs to redline with no problem in netural. since the stutter goes away when you back off i'm leaning towards the TPS but it seems ok when i check it with an ohm meter, so i'm totally stumped. Anyone have any other ideas?
thats what i thought when he told me about the problem, but after looking at it(anf following him to the muffler shop) anytime he gets on it hard it'll smoke like its running rich. maybe a small fuel restriction could be starving it at that many RPMs? car sat from 03 to 08, we'll pull the pump out and check that pre-filter
