gjc5500 Posted July 13, 2010 Share Posted July 13, 2010 I had the same problem. i made a puller using a small puller, piece of Channel iron, and i big bolt and nut. worked good. mine was soo bad that part of the drum stayed on the center of the hub when the rest came off. Quote Link to comment Share on other sites More sharing options...
burninator Posted July 13, 2010 Share Posted July 13, 2010 On 2/22/2010 at 5:43 AM, letitsnow said: Brake cleaner isn't nearly flammable enough. I doubt there's enough volume behind the drum to make an explosion big enough to knock it off anyhow. When burned brake cleaner can be converted in to dangerous gasses. Specifically hydrogen chloride and phosgene. Both are nasty stuff and can cause permanent harmful effects possibly even death being exposed to very small amounts. Hydrogen Chloride Phosgene I'm not saying it happens every time with every brand of brake cleaner, but I wouldn't do it. Check the warning label anyways, and take it seriously. Quote Link to comment Share on other sites More sharing options...
goodoldjam Posted July 15, 2010 Share Posted July 15, 2010 (edited) I tried a hammer at first and then moved to a slide hammer. A large slide Hammer seems to be far easier, you can either hook to the fins or could drill a extra hole in the drum. Start hammering on one side and move to the other and keep alternating. Worked out well, where the normal hammer seemed like a lost cause. Autozone loans out a crappy slide hammer i believe but i think it's only for pulling hubs and doesn't have any attachments. Edited July 15, 2010 by goodoldjam Quote Link to comment Share on other sites More sharing options...
Jesse OBrien Posted July 21, 2010 Author Share Posted July 21, 2010 On 7/13/2010 at 8:12 PM, burninator said: When burned brake cleaner can be converted in to dangerous gasses. Specifically hydrogen chloride and phosgene. Both are nasty stuff and can cause permanent harmful effects possibly even death being exposed to very small amounts. Hydrogen Chloride Phosgene I'm not saying it happens every time with every brand of brake cleaner, but I wouldn't do it. Check the warning label anyways, and take it seriously. Good to know. That must explain all the birth defects I've been having lately. A good charcoal filter goes a long way when you're working with stuff you know if nasty, but don't know HOW nasty. I always play it as safe as I have the means to. Quote Link to comment Share on other sites More sharing options...
