Sputtering issue with stock L28E.
thehelix112
So my car has been off the road for almost a year, so long that the engine is now very unhappy about life.
It'll sputter along running on buggerall cylinders for as long as you can be bothered holding your foot down around 20% throttle.
If you stab the throttle it dies, if you take your foot off it dies.
And there is a decent amount of blue smoke coming off the engine bay. I'm not sure if its the oil/grease from me touching stuff burning off, or if there is somehow a hideous problem and its ingesting massive amounts of oil?
It started like it'd never been stopped, but then quickly developed this problem a few seconds later.
I know very little (nothing) about the stock L28E setup, and couldn't both sit in the car to keep it going and look in the engine bay to try and find the source of the smoke.
Only other thing I can think of is that it had this problem when it sat for a few weeks previously but then came good by itself.
Any suggestions/ideas?
Dave
Little more info.
Let it cool down again (during the week) and tried again yesterday. It starts immediately when its cold, running absolutely rich as hell. I'm surprised it runs, the plugs are not looking happy at all, and it blows amazing amounts of black smoke.
So its running pig-rich. Is there a sensor that I've misplaced or knocked or has died in the past year that could exhibit this behaviour? As the engine warms up it gets worse until it just won't even fire.
Any help appreciated.
Dave
  • Administrators
Dave,
Check the water temp sensor and it's connections (lower thermostat housing). Other things can cause similar symptoms, but poor WT sensor connections are very common with the age of these cars, and cause behavior very much like you describe.
Check for vacuum leaks, damaged connectors and find out where the hell the smoke is coming from!
(e.g. you may have a fractured PCV hose that is leaking onto the exhaust manifold and really screwing up your air metering.)
  • 4 weeks later...
spacecase70, Ben, Thanks so much for the input, much appreciated. The injectors were just cleaned, and I remembered that the exhaust headers developed a huge split recently, and I broke a stud trying to get it off to have it welded up, so it was just welded up on the car, but not completely as he couldn't reach. So thats where the engine bay smoke is coming from.
The issue turned out to be a dodgey connection to the drivers-side coolant temperature sensor. There are two sensors on my car, right next to each other (?!). No idea which is what, but the one that you can hardly see (at night with only a desk lamp for light) was the culprit.
Next issue, clutch master cylinder is blown out I think. :(
Many thanks guys,
Dave
Hmm, so the thermotime switch controls the cold-start injector? Interesting. I thought I tested it when it was struggling by disconnecting the cold-start injector but it didn't make any difference. Maybe I'm mistaken.
I assume you're saying that the thermotime switch controls when the cold-start injector runs? And assumedly that if no signal comes from it, it assumes the engine is in cold-start mode and starts dumping fuel in?
Dave
  • Administrators
Yes.
It shouldn't have made any difference, unless engine temp was below 57F ('78 model. Can't remember if the temp. threshold varied year to year).
Yup.
No. Other way 'round.
Hmmm.. so if the signal is 12V it assumes its in cold-start mode? Indicating that I possibly have a short in that circuit?
Thanks again for all the great info. :)
Dave
When I was troubleshooting my L28E due to failed smog, I blocked off the fuel hose to the cold start valve (in case the Thermotime switch ever fails). The TT switch passed my FSM diagnostic tests, but in CA, I have no need for it, and don't want to risk dumping unneeded extra fuel into the engine.
To block it, I disconnected it from the intake manifold, disconnected the sensor and rubber tube from the fuel rail, and inserted a bolt (sans head - hacksawed that off), so it plugged the gas line. Then button it up and you're set - looks "stock" to emissions inspectors ;)
Thanks BRAAP for that idea!
Good luck - recommend you do the FSM diagnostics - just need a multimeter and a few hours or time - you can eliminate things this way.
