Xylemer Posted December 29, 2009 Share Posted December 29, 2009 Count me in, assuming cost is less than a set of TTT camber plates. I have been wanting to do this myself, but I do not have access to a CNC. I also found this reading on Tom Holts website: http://sth2.com/Z-car/camberplate.htm There is a mine on info there. Thanks Tom Quote Link to comment Share on other sites More sharing options...
BrandenZ Posted January 6, 2010 Share Posted January 6, 2010 Count me in as well, depending on the timing. I'm looking to reassemble my rear suspension in the next month, and then tackle the front shortly thereafter. Quote Link to comment Share on other sites More sharing options...
sbooth Posted January 8, 2010 Share Posted January 8, 2010 Perhaps a company like Daystar who does spacer lift kits of 1-3 inches for jeeps/trucks could tackle this with a thinner insulator of urethane and slightly offset the three mounting bolts so if you rotate the the bolt/hole relationship, you could change the camber slightly. This would be good for the guy who is using full diameter sport springs to create a 1inchish cosmetic rake, and correct mild camber adjustments to his restored but un adjustible suspension. Opinions? Quote Link to comment Share on other sites More sharing options...
lumberjackj Posted February 17, 2010 Author Share Posted February 17, 2010 Perhaps a company like Daystar who does spacer lift kits of 1-3 inches for jeeps/trucks could tackle this with a thinner insulator of urethane and slightly offset the three mounting bolts so if you rotate the the bolt/hole relationship, you could change the camber slightly. This would be good for the guy who is using full diameter sport springs to create a 1inchish cosmetic rake, and correct mild camber adjustments to his restored but un adjustible suspension. Opinions? Its VERY hard to convince a large company like daystar to mess with a few hundred units for a car that is considered "historical".... BUT, give it a try, wouldnt hurt. Im still VERY MUCH considering making these, but dont have much time right now since were busy with a lot of other projects. If I could get someone to draw it up in solidworks, that would be GREAT. Just to give you guys a taste of some CNC porn. Quote Link to comment Share on other sites More sharing options...
lumberjackj Posted February 17, 2010 Author Share Posted February 17, 2010 Count me in, assuming cost is less than a set of TTT camber plates. I have been wanting to do this myself, but I do not have access to a CNC. I also found this reading on Tom Holts website: http://sth2.com/Z-car/camberplate.htm There is a mine on info there. Thanks Tom Thanks Tom!! Quote Link to comment Share on other sites More sharing options...
