datsun79z Posted November 30, 2009 Share Posted November 30, 2009 Question: What attributes combine to make a quality oil filter for an engine, and based on your personal feelings how do some of the "name brand" filters rate? Mike Quote Link to comment Share on other sites More sharing options...
jasper Posted November 30, 2009 Share Posted November 30, 2009 Wix, Mann, Hengst, Napa gold, are some of the quality brands that come to mind. Quote Link to comment Share on other sites More sharing options...
rsicard Posted November 30, 2009 Share Posted November 30, 2009 Question: What attributes combine to make a quality oil filter for an engine, and based on your personal feelings how do some of the "name brand" filters rate? Mike K & N probably has technically the finest Oil Filter produced for mass use. Royal Purple just came out with their performance Oil Filter. Also Amsoil has good oil filters. Quote Link to comment Share on other sites More sharing options...
zman1988 Posted November 30, 2009 Share Posted November 30, 2009 I've found that if you remove the filter housing, the better quality filters will have the media ends glued together (the red areas in the picture). the cheaper filters will just have a string around the media to keep it together. Quote Link to comment Share on other sites More sharing options...
jhm Posted November 30, 2009 Share Posted November 30, 2009 If you do a Google search, you'll be amazed at the number of tests and studies that have been performed on engine oils and filters...here's just a couple: http://people.msoe.edu/~yoderw/oilfilterstudy/oilfilterstudy.html http://minimopar.knizefamily.net/oilfilters/index.html I've been using Purolator PureOne filters on all my vehicles for several years with good results. Quote Link to comment Share on other sites More sharing options...
dhp123166 Posted December 5, 2009 Share Posted December 5, 2009 This is purely opinion and what the OP asked for (I wouldn't want to be accused of not knowing anything), but I find that as long as I religiously change my oil and filter every 3000 miles FRAM and BOSCH filters work fine with organic oil. I just started using synthetic oil and have been told that I can up that time between oil changes 5000 miles. Quote Link to comment Share on other sites More sharing options...
hoov100 Posted December 7, 2009 Share Posted December 7, 2009 Personally, I wouldnt use a filter with a bypass rating, I would use one with a burst rating, just something about the oil actually being filtered, when not at idle. Quote Link to comment Share on other sites More sharing options...
