Oil Filters & thier qualities
datsun79z
Question: What attributes combine to make a quality oil filter for an engine, and based on your personal feelings how do some of the "name brand" filters rate?
Mike
K & N probably has technically the finest Oil Filter produced for mass use. Royal Purple just came out with their performance Oil Filter. Also Amsoil has good oil filters.
If you do a Google search, you'll be amazed at the number of tests and studies that have been performed on engine oils and filters...here's just a couple:
http://people.msoe.edu/~yoderw/oilfilterstudy/oilfilterstudy.html
http://minimopar.knizefamily.net/oilfilters/index.html
I've been using Purolator PureOne filters on all my vehicles for several years with good results.
This is purely opinion and what the OP asked for (I wouldn't want to be accused of not knowing anything), but I find that as long as I religiously change my oil and filter every 3000 miles FRAM and BOSCH filters work fine with organic oil.
I just started using synthetic oil and have been told that I can up that time between oil changes 5000 miles.
