Vacaville Velo Rossa
Radiator from Stealth Conversions arrived this week. I had a few minutes between home repairs....
... and slipped it in easily.
post-4015-074823400 1303584733_thumb.jpgpost-4015-045156200 1303584736_thumb.jpg
Mounted my Taurus fan to the radiator. I considered several different options after looking at many pics here at HybridZ. I eventually settled on what turned out to be a pretty simple solution. I attached the vertical plastic edge flange on each side of the shroud to 1 1/2" x 1/4" aluminum bar using stainless steel rivets.. The bar width is enough to extend to the existing mounting bolts for the threaded 3/4" aluminum bar that came on the JTR/Stealth radiator brackets. I simply drilled holes in the new bars at those locations and used the same bolts to reattach everything.
I think it looks pretty clean.
Progress on several fronts over the last couple of weeks.
First I wired up the dual speed radiator cooling fan with the help of this thread...
http://forums.hybrid...__1#entry921201
...and it's associated links.
I got all of my parts at the local Pick N Pull.
Dual Speed Taurus Fan $35
Volvo Fan Relay w/plugs $10
BMW Temp. Switch w/plug $ 7
Total $52
Next I went to work on the hydraulic clutch system.
The Tilton .850 master cylinder, ($85 from Summit Racing)...
post-4015-028832400 1306808182_thumb.jpgpost-4015-069437900 1306808179_thumb.jpg
...connects to the Camaro slave cylinder ($35 at O Reilly Auto) with a blue -3 an coupler ($2.45 Summit), a 32" -3 an 90 degree hose ($17 Summit) and a 'GM clutch cylinder to -3 an' adapter ($32 Summit).
Total cost about $90.
Very clean when installed.
  • 4 weeks later...
Ordered the Factory Five Racing Le Mans style gas cap yesterday.
post-4015-047593100 1309149332.txt
Still playing with wheels.
And with the assistance of my wife, bled both the brake and clutch systems. Good news... NO LEAKS!!!!! wink.gif
This is gorgeous. I really appreciate the write-up. I'm currently in the midst of tearing down my '77 and pulling a LT1+T56 for it, and I'm really tempted by the VR kit. It really is a thing of beauty.
This is gorgeous. ... pulling a LT1+T56 for it, and I'm really tempted by the VR kit. It really is a thing of beauty.
Thanks Kito.
I agree. The VR body is sleek, elegant and unique. I know it's not the popular view, but I like the look of this roadster much more than the original fastback Ferrari 250 GTO. If you'e truly considering this re-body, just remember that it's not a bolt on affair. You'll have, in my opinion, triple the amount of work over your engine/tranny swap. I thought I was through with mods a couple months ago, but I keep finding areas that just don't feel finished.
For instance, I spent some time today trying to make an inner fender for the front end. The headlights, turn signals and front vents are visible through the front wheel openings.
Here's my current solution.
Sorry pics won't load. I'll try a new post.
Edited by Fauxre
Here's what I'm trying now.
A removable fiberglass inner fender ...
...that will block off and protect the light assemblies from road debris and finish off the wheel well when the bonnet is down.
Working on the fuel pocket today. It's too big for my taste, so I'm trying a couple different looks.
The walls are set at right angles to the bottom...
...I created sloping walls, by stretching fiberglass cloth from the center hole to the pocket edges and securing it with tape.
The resulting insert...
... makes for a more appealing pocket.
But I still think it's too big.
To get the pocket tighter to the gas cap, I lined the pocket with foil...
...inserted the gas cap...
...and filled the gap with expanding foam.
A little trimming and carving...
post-4015-094140300 1310192261_thumb.jpgpost-4015-096942000 1310192038_thumb.jpg
Some more carving and I think I'll have something I'll like. I'll use the foam plug to make a piece that can be permanently glassed to the body.
  • 3 weeks later...
With no new parts coming my way in the next month (keeping a cash cushion for our son's up coming wedding) I've decided to get going on fitment and clean up on some interior parts.
Started with the seats. The reclining release mechanisms rub on the reinforcement used to strengthen the unibody after the top was chopped. Simple fix. I swapped the seats from side to side, putting the release handles next to the tunnel, where there's plenty of room.
Todays job was refurbishing the door glass. A little steel wool, some elbow grease and a coat of paint for the metal pieces, brings back the original shine. I'll start in on the tracks tomorrow.post-4015-003537400 1312466083_thumb.jpg
Next time you need to stretch some cloth for a form fit, try using some fleece. Secure it how ever it needs to be, then pull it taught, and secure it it on the other edge. It works well, when you have some very irregular shapes and need to fill in spans. I use this technique regularly in car audio installations and interior work, for speaker enclosures, amp racks and trim panels.
