Vacaville Velo Rossa
  • 4 weeks later...
Started the fuel tank installation by adapting my Z fuel sending unit to my new '56 Chevy fuel tank. I chose to keep the five bolt mounting set up of the tank in case I later decide to switch to aftermarket gauges.
The first step was to adjust the travel of the float. In the old Z tank, the float travels almost 11 inches in it's arc from empty to full. The new tank is only eight inches tall. I cut the float arm and adjusted the length until the float's arc was about 7 1/2 inches. I wrapped the float arm with a little wire to hold it together.
I then hooked up test wires and checked the gauge readout. A little fine tuning, accomplished by bending the float arm, and it works perfectly. I then spot welded the two pieces of float arm and ground it smooth.
I then drilled the five holes into the sending unit rim.
The raised center portion of the unit won't allow the mounting bolts to lay flat, so I made a spacer out of a large washer.
post-4015-096670100 1317611890_thumb.jpgpost-4015-095879000 1317611893_thumb.jpg
The spacer makes a nice retaining ring.
post-4015-097547400 1317611898_thumb.jpgpost-4015-087193600 1317611927_thumb.jpg
I'll cut more of the trunk floor and finalize the position under the car, then fab some mounts, install the pick up tube and vent and make a new trunk floor.
Cut out the rest of the trunk floor...
Drilled hole for 3/8 pipe threaded bung...
Brazed bung in...
installed pick up tube...
and positioned tank before starting to fab some mounts.
Still need to figure out where to add a vent to the tank.
Now that the location of the fuel tank has been finalized, I've begun routing the filler neck to the gas cap. I bought this tank, in part, because the filler seemed to be in the best location for my project. It quickly became apparent that running the tube on the underside of the trunk to an existing hole, then up to the cap was going to be problematic. It required more complex bends than I anticipated and I'm concerned it will end up too close to the exhaust and muffler.
My solution was to modify the inlet at the tank to come up through the trunk floor, then connect to the cap with a flexible connector. I'll lose some usable trunk space, but I like that better than the possibility of heating gas vapors.
post-4015-044234500 1318820244_thumb.jpgpost-4015-097464800 1318820246_thumb.jpgpost-4015-002162600 1318820248_thumb.jpgpost-4015-094225600 1318820248_thumb.jpgpost-4015-092726700 1318820249_thumb.jpgpost-4015-006505800 1318820251_thumb.jpg
Edited by Fauxre
Time to mount the new fuel pump.
The old pump and filter fit neatly in the heavy bracket.
The new pump will fit nicely as well...
Unfortunately the old mounting location is now occupied by one leg of the new fuel tank mount. I played around with the bracket and finally decided to try the mount on the passenger side as close to the rear valance as possible. The curved portion of the bracket is no longer required...
post-4015-097099700 1319685186_thumb.jpgpost-4015-071866700 1319685266_thumb.jpg
...so, I pounded it straight, cut it off even with the other side, sand blasted it clean, cut a new hole for the fuel line, painted it and attached the new pump.
In its new location, the old bracket provides considerable protection from possible road debris and (I'm hoping) from exhaust heat since the muffler will run through the gap between the pump and fuel tank.
Added a vent tube and painted the tank with zinc coating from Eastwood.
Welded up the trunk floor framing from more scrap square tubing. The trunk opening is to small to allow a single floor piece, so I made three sections.
post-4015-094435000 1320801638_thumb.jpgpost-4015-085462100 1320801639_thumb.jpgpost-4015-084382100 1320801641_thumb.jpgpost-4015-047753500 1320801644_thumb.jpg
Looks good covered, but the hardboard concerns me. It'll need to be protected from moisture. So, I might use these panels as patterns for fiberglass replacements. Undecided.
post-4015-046564500 1320801646_thumb.jpgpost-4015-047672700 1320801647_thumb.jpg
Edited by Fauxre
  • 3 weeks later...
Latest progress:
Completed the new fuel lines (3/8 solid aluminum) from tank to engine compartment. Still need to run flexible line to the carb.
Sealed the hardboard trunk floor panels with fiberglass resin and coated the underside with a layer of matting for extra strength.
Started making 'front fender well to door jam' block-off panels from fiberglass. I started by filling the gap between the unibody and cheek panel with floral foam blocks, and sculpting them to shape. I used a hot glue gun the attach each block to the inside of the cheek panel. After removing the cheek panel, I covered every thing with fiberglass matting. The resulting panel needs a lot of refining, as it came out very uneven and needs an extension to reach the old unibody. I'd prefer to make the block-off a permanent part of the cheek panel, but I'm not sure I can make it work with the way the panel rests on top of the old sheet metal.
post-4015-005505600 1322346285_thumb.jpgpost-4015-011664200 1322346286_thumb.jpgpost-4015-017712900 1322346287_thumb.jpgpost-4015-020353400 1322346289_thumb.jpgpost-4015-023701100 1322346290_thumb.jpgpost-4015-036913400 1322346291_thumb.jpgpost-4015-035760100 1322346292_thumb.jpgpost-4015-043292900 1322346293_thumb.jpgpost-4015-026081800 1322346294_thumb.jpgpost-4015-029274900 1322346295_thumb.jpg
Needed a break from resin fumes, so I turned my attention to the differential mount and crossmember modifications. Originally I was going with the stock diff front mount setup, as my donor cars previous owner had provided me with all new parts at purchase. But, since I will be running duel exhaust, it became clear to me that the crossmember needed to be modified for better ground clearance. After exhaustive forum searches, it also became clear that it would be far better to convert to the RT mount, eliminating the problems of trying to retain a bottom mount location on a modified crossmember. Here's my solution:
I purchased two crossmembers at Pick N Pull for $18 each.
Using one crossmember, I made a welding jig from some scrap steel.
post-4015-031148400 1322349300_thumb.jpgpost-4015-023136200 1322349301_thumb.jpg
I cut the crossmembers in half and welded the two pieces with exhaust recesses together.
post-4015-028532000 1322349491_thumb.jpgpost-4015-023726000 1322349492_thumb.jpgpost-4015-014835400 1322349489_thumb.jpg
I notched the area that interferes with the diff mounting bolt and welded in angle stock.
post-4015-021163700 1322349490_thumb.jpgpost-4015-024939900 1322349280_thumb.jpgpost-4015-028680200 1322349281_thumb.jpg
A little paint, and it's done.
  • 3 weeks later...
I thoroughly enjoy watching your build. Great work!
Vacaville huh? I live in Vacaville! Small world, great looking project! Keep up the good work!
Yup. Been here 20 years now. If all goes well you might see it driving around town this spring.2thumbs.gif
Meanwhile, back at the build...
My original plan was to relocate the battery to the trunk. But, after making some temporary panels, it's clear to me that there just isn't enough space to hide a battery. So, it's back to the stock location in the engine compartment. There was a lot of corrosion on, and under the original battery tray, so years ago, I cut it out and treated the area.
I fabbed up this new tray and bolted it to the fire wall and inner fender.
It sits a little higher than stock, but with a a couple measurements, a suitable battery was easy to find at the local O'Reilly's.
Up next is completing the wiring per the JTR V8 Conversion Manual.
I've started working on the wiring. The JTR manual had me totally confused at first, but I'm starting to get it. And instead of just bypassing the ignition interlock system, I'm going to remove it completely... along with a lot of wiring that I no longer need (i.e. dome light, rear window defogger, etc).
  • 1 month later...
Well, after a month and a half, I've got the electrical figured out.
I was having a lot of trouble following the wires on the schematic, even after Kinkos enlarged it to hang on the wall in the garage. All those little black lines running parallel... it was too easy to get them crossed. So, I spent a great deal of time with my favorite imaging program, and colored in all the wires I would be keeping. Working back and forth from computer to car, I added in the new GM components, a 12V junction bar and the newly routed wires.
All the the current electrical systems are now operational. It's amazing that a simple flashing light could make me feel soooooo good.
If all goes well, I may fire the engine for the first time this weekend.
