DRFTEM Posted December 12, 2009 Share Posted December 12, 2009 Ok My wipers arent working. I have tried swapping switches and it made no change. How can I test my wiper motor to make sure it works? Does it require just hooking up a power and ground to certain wires? Basically I need to trace down if it is a wiring issue , the wiper motor, or the switch i just got. Please someone tell me how to test my wiper motor. I might just hook it up to some toggle switches to make it work for now. It has been raining and I now cant drive my z due to no working wipers. Any and all help appreciated. Quote Link to comment Share on other sites More sharing options...
DRFTEM Posted December 12, 2009 Author Share Posted December 12, 2009 ok i found that the blue/red is 12v constant and the black is ground. do the speed wires get a ground or power? I dont wanna frie it so ill wate for a response.The motor isnt getting any power with the car running so Im assuming its a wiring issue so I now need to test if I can wire it up to work with some switches. Quote Link to comment Share on other sites More sharing options...
19762802+2 Posted December 12, 2009 Share Posted December 12, 2009 It might not be the wiring I had to take out my motor and clean the contacts and the motor because it had corroded a small amount because leaves had plugged up the drains in the cowl area and well you get the point. My wiper motor even worked before it stopped working then just stopped, so you might want to try that out also what year Z the wiper motor is in would help. Quote Link to comment Share on other sites More sharing options...
DRFTEM Posted December 12, 2009 Author Share Posted December 12, 2009 Its in a 74 260z. so noone knows if the wires get power or are a ground? Quote Link to comment Share on other sites More sharing options...
DRFTEM Posted December 13, 2009 Author Share Posted December 13, 2009 ok turned out my wiper motor wasnt moving because the pivots had siezed on the passenger side wiper arm. so now I bought another wiper motor so it is for sale. Quote Link to comment Share on other sites More sharing options...
jhm Posted December 15, 2009 Share Posted December 15, 2009 Sounds like you got your wipers working....but just FYI, another source of wiper failure can be a poor connection in the wiring plug in the engine compartment. The plug is mounted high on the firewall (passenger side), and the connections can often get corroded. Easy job to open the plug and clean the connections. Quote Link to comment Share on other sites More sharing options...
deja Posted December 15, 2009 Share Posted December 15, 2009 This is for a 280Z but its probably the same for the 260Z. Quote Link to comment Share on other sites More sharing options...
Zdrivertwitch Posted December 18, 2009 Share Posted December 18, 2009 Anyone have this same Diagram ^^^ Just for the 240Z. It's a '71 if that helps at all. Quote Link to comment Share on other sites More sharing options...
Mario Posted January 1, 2010 Share Posted January 1, 2010 I have a 240 and my wiper motor does not work I am tires of using rain X . how much you want for you wiper motor? Quote Link to comment Share on other sites More sharing options...
