Crazyoctopus 1972 240z build up (long first post)
just finished reading the entire thread.... you are a beast, and your car is a work of art. great stance, color scheme, triple weber setup... :hail: but i was a little confused on your weather strip setup... u said rx7 FC for the hatch and a volvo 740 wagon for the doors???? how did that work out??? :confused2
thank you kindly for the compliments :)
fits like a charm. look at where the cut is on the doors, if you cut father towards the engine bay on the bottom door sill you will have a bulge in the stripping.
As for the hatch, it fits awesomely with a small cut.
Adding Lightness, one of my favorite automotive terms and soo much fun to do!
Dont cut here or your door will lose A LOT of rigidity.
How I keep the door lock in place
How the window is held in place: one screw, two nylon nuts, two washers, and a wingnut
I split some windshield washer line (they ran out of super small vac. lines) to cover up the burs in the door, 10 foot per door.
Painted
Techno Toy Tuning Rear Lower Control Arm install
Fender cut
Front geometry, just a hair above parallel; may do the subframe notch in the future though...
Just a thought, maybe you should throw something over the inside of the doors just in case in some freak accident the glass shatters you won't get blasted in the eye with glass particles.
I got the impression from the photos that they where plexiglass.
yep plexiglass, so shattering it would nearly be out of the question.
Yea I'm a retard, totally read past that part.
What was your camera mounted to? One time I strapped mine to my rear view mirror with zip ties and rubber bands and it turned out well. Did it once on a harness bar and it also come out good.
After reviewing how people have mounted their brake proportioning valves, I figured that i would make mine even cheaper and easier.
Items purchased:
two 1/4" bolts, 2 lock washers, two 1/4" nuts, set of four rubber washers cost - $2
40" of 3/8" std brake lines cost - $6
Total cost $8
Since I had an extra two SS brake lines from the MSA brake line kit, I used those for the conversion; that way i could use the 2 spare 10mm x 1 brake ends that would have been thrown away if i didn't.
To top it off I didn't have to make, or buy a mounting bracket.
