hoov100 Posted January 4, 2010 Share Posted January 4, 2010 before i blow some change on the MM caliper brackets, has anyone tried using z32 rear calipers with the maxima brackets and z31 vented rotors? Quote Link to comment Share on other sites More sharing options...
michaelp Posted January 4, 2010 Share Posted January 4, 2010 Z31 vented rotors are 5 lug only. Also, what would you do for an e-brake? Quote Link to comment Share on other sites More sharing options...
hoov100 Posted January 4, 2010 Author Share Posted January 4, 2010 Z31 vented rotors are 5 lug only. Also, what would you do for an e-brake? secondary mechanical brake calipers, I've got my own stub axle/CV setup, which gives me CV's without adapter and without bottoming out the and driverside axle and z315 lug stub's. Quote Link to comment Share on other sites More sharing options...
michaelp Posted January 4, 2010 Share Posted January 4, 2010 Is that "much" REALLY needed in the REAR of an S30? How much power are you making? Quote Link to comment Share on other sites More sharing options...
hoov100 Posted January 4, 2010 Author Share Posted January 4, 2010 Is that "much" REALLY needed in the REAR of an S30? How much power are you making? Not really doing it to handle obscene amounts of power, but at the end of the day after the machining and welding its going to be cheaper then even a set of the CV adapters. Quote Link to comment Share on other sites More sharing options...
CArFAn Posted January 4, 2010 Share Posted January 4, 2010 So when using s13 calipers on the rear can you use z31 5 lug vented rotors right? Or z32 rotors with s13 calipers. If none of the will work what will work thata 5 lug on a s13 caliper. Quote Link to comment Share on other sites More sharing options...
hoov100 Posted January 4, 2010 Author Share Posted January 4, 2010 So when using s13 calipers on the rear can you use z31 5 lug vented rotors right? Or z32 rotors with s13 calipers. If none of the will work what will work thata 5 lug on a s13 caliper. z32 rear 2 piston calipers and z31 vented rotors for brakes, for the ebrake I was thinking of some along the lines of using a separate caliper, but no ebrake for now until i figure this out. Quote Link to comment Share on other sites More sharing options...
CArFAn Posted January 4, 2010 Share Posted January 4, 2010 Im going to look at some pics and hope its not to difficult. Just looked at a few pics and i never knew the ebrake for a z32 was an internal drum type deal so i think im going to use s14 rotors or have some s13 rotors redrilled. Quote Link to comment Share on other sites More sharing options...
