Transmission change out
Delasangre4231
I am about to replace my tranny on my 84 turbo with a new one and have a question. When I am going to put in the new one do I put new fluid in and then put it in or do I install everything and then put fluid in? If the latter how does the fluid go in without some kind of pump. Do I pour it in via the shifter hole and put my finger in the side hole to see the level? Isn't it supposed to be right at the side drain hole when its level?
I know that I was able to pour fluid in the top through the shifter hole when we were doing my friends Nissan pickup trans, but I am not to sure how to do it with this one. I will unwrap the new one in a few days and look. I'm only concerned because if I switch all this out in my driveway and the only way to fill the trans is a pump then I don't know how I will get to a shop.
Easier to fill it while sitting on hte ground. Then duct tape a plastic bag around the tail end so you don't spill fluid all over the place when moving around. As long as you keep it level you won't get any spills but sometimes things happen. While you have it out be sure you can remove the fill plug as well as the drain plug. You can fill it in place but either need to go thru the shifter boot or a long hose out and under from the car in the fill hole then utilize gravity to fill but usually a two person job and messy.
