NewZed Posted January 21, 2010 Share Posted January 21, 2010 I just put a 5 speed from a 1978 280Z in my 1976. It works fine but I find that it is scarily easy to hit reverse accidentally on the way back down to 4th gear from 5th. I saw in an earlier post that the 1980 5 speed was the first to come with a reverse lockout. http://forums.hybridz.org/showthread.php?t=101796&page=2 Does anyone know of a fix, mod or upgrade to the 1978 transmission or shifter or console that will provide a reverse lockout? Are they all this way or could mine be broken? As it is, I have to downshift to 4th with a very light grip to keep it away from reverse. I have a 5 speed 95 Pathfinder so I know what a "normal" 5 to 4 shift feels like. The drain plug came out really clean in mine, so it looks like the PO didn't grind things too many times, but I would like to be able to drop down to 4th gear at speed quickly without worrying about destroying reverse. Any ideas are appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
260DET Posted January 29, 2010 Share Posted January 29, 2010 I always thought all five speeds had a reverse lockout. Have you checked if your box has one? If it does then it may be stuffed but that would be unusual. Quote Link to comment Share on other sites More sharing options...
NewZed Posted January 29, 2010 Author Share Posted January 29, 2010 I think that the early 5-speeds had more of a reverse "avoidance" system of springs and check balls in the shifting mechanism. At least as far as I can tell from the FSM diagrams. I actually spent some time comparing the 78, 79, 80 and 81 5-speed shifter diagrams and can not find a difference in parts, except for what appears to be one extra "check spring" in 1981. So I don't know what the 1980 "lockout" is that is referred to in the other thread http://forums.hybridz.org/showthread.php?t=101796&page=2 I was hoping that someone with more experience with Datsun shifters than me would be familiar with what I was talking about and have some recommendations. Compared to other 5-speeds I have driven this one is just way too easy to drop in to reverse while moving forward. I don't know if it's design weakness of the early 5-speeds or something that can be adjusted/fixed. There is very little guidance back over to 4th gear when pulling the shift lever down from 5th. The transmission came out of a car that sat for 10 years. It may just be that the spring is tired or things are gummed up. I didn't take the tranny or shifter apart, but the oil was clean so I didn't expect any problems. Thanks for the help. It's not a show-stopper as far as driving, but it definitely needs improvement if I can figure it out. Quote Link to comment Share on other sites More sharing options...
