Guest TurboHatch Posted January 30, 2010 Share Posted January 30, 2010 I just purchased a 3.54 r200 off a guy on here with plans to swap my 3.70 r200s LSD over to it, however im not sure if i am understanding what i am reading but it seems i may run into a issue with bolt sizes? So if there are two styles of r200 carriers is there any way i can tell before i yank the rear out of the car or is the only way to tell by pulling it apart and seeing what size bolts are being used? some one said i can use bushings or something like that if the bolts are the wrong size or drill the diff out, can any one please shed light on this so i am properly equipped for doing this. thanks Quote Link to comment Share on other sites More sharing options...
B00STDZ Posted January 30, 2010 Share Posted January 30, 2010 ??? Never heard that. I was always told if the ring gear size and the spline count are the same then they are swappable... Making it possible to either put the lsd in the 3.54 open or take the ring and pinion gears out of the 3.54 and put it in the lsd. I plan on swapping a lsd in a 3.36 R200... Quote Link to comment Share on other sites More sharing options...
hoov100 Posted January 30, 2010 Share Posted January 30, 2010 long nose z31 and short nose R200's have a 12mm ring gear bolt, while the s30 and s130 have 10mm ring gear bolts if I'm not mistaken. Also any R200 rear diff cover will bolt on to any R200 housing, the only thing that changes is the spacing between the mounting studs. As far as I know. Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted January 30, 2010 Share Posted January 30, 2010 What Hoov said is correct but ill shed some more light on the subject also. Some say that you need to make some spacers some say you dont. I am currently running a 3.54 out of an 82 zxt with a lsd out of a 300zx and i am actually not using any spacers. The bolts are not what centers the ring gear on the carrier. And the Clamping force is enough to keep the ring gear from spinning. I recently took mine apart and it had not moved and thats with launching hard many times at the strip and doing 12sec passes. Quote Link to comment Share on other sites More sharing options...
Guest TurboHatch Posted January 30, 2010 Share Posted January 30, 2010 Thanks for the info guys, and zeeyah nice score on a 3.36 diff i REALLY should have one of those as well, even with the 3.54 i will be spinning past the cams power level if i stay in 4th gear, the entire reason i am swapping is i dont want to have to use 5th gear at the strip. jeffer949 i know what you mean the OBX in my honda was sort of loose like that and worked fine. Quote Link to comment Share on other sites More sharing options...
B00STDZ Posted January 30, 2010 Share Posted January 30, 2010 TurboHatch said: zeeyah nice score on a 3.36 diff i REALLY should have one of those as well, http://forums.hybridz.org/showthread.php?t=158867 There she is... out of a 260z 2+2 manual transmission... Quote Link to comment Share on other sites More sharing options...
B00STDZ Posted January 31, 2010 Share Posted January 31, 2010 Btw to the OP here is a thread you can read... http://forums.hybridz.org/showthread.php?t=98756&page=2 Quote Link to comment Share on other sites More sharing options...
Guest TurboHatch Posted January 31, 2010 Share Posted January 31, 2010 ok good info guys, my next question is what are the torque specs for the diff ring, and end caps? Quote Link to comment Share on other sites More sharing options...
B00STDZ Posted February 6, 2010 Share Posted February 6, 2010 Not sure how accurate this is but I thought I would throw it out there... Quote Link to comment Share on other sites More sharing options...
piston Posted February 6, 2010 Share Posted February 6, 2010 (edited) talk about r200. i just finished flipping my z31t axle cages. what a mess. new boots n all installed! im going to stick with the weak 3.54 longnose r200+ z31t axles. hope it handles when the time comes. no lsd. im broke!!! not to change the subject but when i spin my diff flange for the drive shaft, it has a slight barely noticeable click before it spins the axles. however it is empty and has no oil. is this normal? Edited February 6, 2010 by piston edit Quote Link to comment Share on other sites More sharing options...
