grumpyvette Posted February 2, 2010 Share Posted February 2, 2010 BTW if your ignition, or any other electrical component is blowing fuses step one is getting a shop manual so you can easily trace the wires and colors, obviously if it blowing the fuse the indications point to a short or ground, being the cause,but a component that got wet or a wire that got pinched during an accident or during a repair is most likely, I generally remove the fuse and Ive got a test fuse I soldered two wire leads to that connect to a 9 volt battery powered buzzer, it plugs in where I removed the fuse and buzzes,unlike a light so you don,t need to keep looking at it, I then I go looking for loose or rusted connectors, pinched wires, loose grounds, etc. when you find one the buzzer either tends to get louder or stops you simply take a blown fuse and solder the leads to the buzzer to the legs and insert it into the fuse box just during testing, but its a very good idea to put a inline fuse in the leads so you don,t have problems, obviously you don,t need more problems caused by testing http://www.radioshack.com/product/index.jsp?productId=2102786 http://www.futurlec.com/Buzzers.shtml Quote Link to comment Share on other sites More sharing options...
at-jefft Posted February 2, 2010 Share Posted February 2, 2010 genius! Quote Link to comment Share on other sites More sharing options...
leftover z Posted February 2, 2010 Share Posted February 2, 2010 That is wicked smart Grumpy! I am going to make one of those myself. Quote Link to comment Share on other sites More sharing options...
MONGO510 Posted February 3, 2010 Share Posted February 3, 2010 I use something similar that uses a automotive circuit breaker instead of fuse. It will save a bunch in fuses and reset itself. Quote Link to comment Share on other sites More sharing options...
turboHLS30 Posted February 3, 2010 Share Posted February 3, 2010 Will this work for any car, because my 72 Suburban's brake lights won't light up. Quote Link to comment Share on other sites More sharing options...
