Need Some S30 Brake Info
too bad i work at napa and get unbeatable deals. probably like 17.00-20.00 a piece for me.
That's one hell of a discount considering the NAPA website says $73.94 at my local store.
So, what's the difference between the 240Z and 280Z rotors that make such a big price difference?
your correct. the 240z for no damn reason is $72.49 retail.
however, the 260z and 280z came up with a cheaper affordable rotor for $26.99. someone at our corp office must be on crack.
240z rotor info.
# of Bolt Holes : 4
Bolt Circle Diameter : 103 mm
Brake Rotor Diameter : 10.67"
Brake Rotor Discard Thickness : .41"
Brake Rotor Thickness New : .49"
Brake Rotor Type : Disc Brake Rotor Only
Center Hole Diameter : 3.19"
Height : 2.02"
Maximum Lateral Runout : .004"
Mounting Type : Type L - Rotor Only. The Rotor Is Mounted Inboard Of The Hub. The Hub & Rotor Sections Are Bolted Together. Replace The Complete Assembly If Hub Flange Is Bent Or Damaged. See Diagram For More Information.
Vented / Solid : Solid
260-280z rotor info.
# of Bolt Holes : 4
Height : 1.7"
guess the height is the differnce between the two. that is why the hub spacers are also different in thickness when converting to vented z31 rotors depending on hubs being used.
Edited by piston
edit
