ktmp Posted March 7, 2010 Share Posted March 7, 2010 I've got my LS1 into my z and am using a 4 core aluminum Ron Davis Radiator. It has a standard upper radiator hose connection but the lower connection is a 1" threaded NPT connection. I can find many fittings that are NPT but is it a problem since it's only a 1" fitting? Will that allow enough antifreeze to travel? I can't find the answer anywhere. THANKS Quote Link to comment Share on other sites More sharing options...
mark Posted March 7, 2010 Share Posted March 7, 2010 call Ron Davis and ask. I've talked to those guys a couple of times and they have been very helpful. Quote Link to comment Share on other sites More sharing options...
benitoz Posted March 7, 2010 Share Posted March 7, 2010 This guy on ebay sells a kit to put -an fitting on your water pump.. heres the link http://cgi.ebay.com/ebaymotors/LS1-LS2-Swap-Universal-Adapter-Thermostat-Housing-180_W0QQcmdZViewItemQQhashZitem1c0dbe36b3QQitemZ120489653939QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories Quote Link to comment Share on other sites More sharing options...
ColtGT4g63 Posted March 7, 2010 Share Posted March 7, 2010 I used a piece of metal on my upper radiator hose to join two different rubber hoses together. The ID of the piece of metal was probably close to 1" if I can remember. Never had an over heating issue at all. Coolant doesn't flow nearly as fast as your intake / exhaust. So a small restriction won't be the end of the world. Quote Link to comment Share on other sites More sharing options...
janaka Posted March 7, 2010 Share Posted March 7, 2010 i did as above with a metal pipe between rubber hose and i'd say mine is maybe 1" ID maybe a hair bigger at best. I definately have NO issues at all. See the below pic for the pipe I have run. Quote Link to comment Share on other sites More sharing options...
ktmp Posted March 7, 2010 Author Share Posted March 7, 2010 I posted this over at LS1 forums and one member said that if the outlet isn't the same size as the water pump, I would end up with "cavitating" issues? Did you guys have any problems with any of that? I'm having to modify my car to make this rad fit and I only want to have to do it once. THANKS Quote Link to comment Share on other sites More sharing options...
MikeJTR Posted March 8, 2010 Share Posted March 8, 2010 This is yet another shameless plug for JTR. If you need a hose splicer that goes from one size to another, see this link: http://www.jagsthatrun.com/Pages/Parts_Cooling_TransHoseSplicers.html We make these parts inhouse. If you need a special size, let us know, we can usually make these within a week. If you splice hoses together, with a straight piece of pipe or tubing, and the ends are not beaded, the hose can slip off. For safety reasons, you should use hose splicers with beaded ends. Quote Link to comment Share on other sites More sharing options...
ktmp Posted March 8, 2010 Author Share Posted March 8, 2010 This is yet another shameless plug for JTR. If you need a hose splicer that goes from one size to another, see this link: http://www.jagsthatrun.com/Pages/Parts_Cooling_TransHoseSplicers.html We make these parts inhouse. If you need a special size, let us know, we can usually make these within a week. If you splice hoses together, with a straight piece of pipe or tubing, and the ends are not beaded, the hose can slip off. For safety reasons, you should use hose splicers with beaded ends. Those things are awesome! My problem is that the outlet on the lower radiator is only 1" and I am doubting enough coolant can pass through it. Question: Do you have those hose splicers in aluminum and in a 90 degree bend? THANKS Quote Link to comment Share on other sites More sharing options...
